Oil Filter questions on v6
Discussion in 'Technical Chat' started by khfactor, Dec 9, 2007.
  1. Dec 9, 2007 at 3:15 PM
    khfactor
    khfactor [OP] Well-Known Member
    Philadelphia, PA
    07 White TRD Sport
    Pop N Lock + Hose Clamp. DTRL, AFE drop-In Dry filter, 6-1/2" Replacement Speakers, JVC HD Radio, Sam's club variety Floor mats (cheap but effective), Chrome Exhaust tip, Bed Mat from ol' Ford Ranger. As of 3/25/2020, the Odometer just turned 70K.
    I noticed that the Oil filter is mounted neat the top of the engine on v-6 Tacomas. I have never had a car / truck that has an oil filter sticking up like that. Normally one would crawl under the truck / car and unscrew the filter to remove it.
    But the Taco's oil filter sticking up like this, how would you remove it WITHOUT spilling oil all over the place when unscrewing the filter? Is there a clever way to catch oil when you unscrew the filter, perhaps some form of a "mini" pan?
    Thanks,
  2. Dec 9, 2007 at 3:43 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Yes there is, on the bottom of the filter base is a nipple, you must pull off the little rubber cap and insert a hose that runs from the base to your oil recycle/containment vessel, (which is at your local auto parts store) This new configuration does keep the oil from running down your arm, which is cool.
  3. Dec 9, 2007 at 4:06 PM
    camt10
    camt10 Well-Known Member
    03 ext cab sr5 trd 4x4
    what i usally do is being around brake clean in the shop just grab a cap off the brake clean can, put it under the nipple pop the cap and let it drain
  4. Dec 9, 2007 at 4:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    usually, i just pull off the nipple, and put an old pepsi bottle or old gatorade bottle under there, drain my oil for a bit, then unscrew the filter. by then,most of the oil has already drained, and very little is left coming outta the filter.
  5. Dec 17, 2007 at 1:58 AM
    vivafire
    vivafire Well-Known Member
    Galveston,Texas
    2024 TRD 4X4 OFF ROAD
    Just Amber LED turn signal lights for now
    This is why I love the forum,I learn something new everytime I come here.:thumbsup:
  6. Dec 17, 2007 at 5:34 AM
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    Ditto !! I learned so much from this forum on "how-to's" than 4 years of college + 3 more years in Grad school: dare I say it, from the school of engineering, mechanical engineering department at that!
    So when I see some posts from members claiming that they cannot figure out without pics as they are NOT an engineer, I cannot say the same as I IS AN ENGINEER, not a good one I guess..... :rolleyes:
  7. Dec 17, 2007 at 3:56 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I just changed my oil for the first time this evening, and I was incredibly amused at the brilliance that this litltle drain spout thing is. It was absolutely amazing. I just ran a piece of tubing from the nipple to the drain pan. but hell, even I just learned something new tonight and will toss the tubing and go with the pepsi bottle route as that is even less kneeling and bending.
    Thanks guys.
  8. Dec 17, 2007 at 4:02 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Lotta nipple yanking here!:D
  9. Dec 17, 2007 at 4:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :D.......definitely man!!!
  10. Dec 18, 2007 at 5:17 PM
    concrete jedi
    Rochester N.Y
    It's not nice to tease ! :eek:
  11. Dec 18, 2007 at 5:56 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    What oil and filters are recommended. Im pretty sure im going with Mobil 1, but what viscosity?
  12. Dec 18, 2007 at 6:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i say its probably best to stay with 5w30(i've used pennzoil platinum and mobil1)......although in some cases(weather being one), some people are using 10w30, 0w30 and 5w20. where you are though, i think 5w30 will do just fine. as far as the filters, i use a mobil1 m1-102. you can also use the m1-209.....as it will flow a little more oil. alot of people are using amsoil filters also, as well as napa gold and wix filters.
  13. Dec 18, 2007 at 6:24 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I personally like to use the factory filter , my dealer gives a discount if I purchase 3 at a time and that saves trips there anyway. I have run Mobil 1 5w-30 since new and change every 5000 mi. 134k on it now.The oil filter drain funnel thing was a much needed improvement over the 1st generation Tacoma.If I dont take the time to remove skid-plates, no matter how many paper towels or even a oil soak pad wont catch the oil that runs out of the filter.The oil will then drip all over hell in the driveway..so I go park it on an incline to let drain off the skid plate.
  14. Dec 18, 2007 at 6:48 PM
    TacoSupreme
    TacoSupreme Well-Known Member
    007 DC Cuatro Por Cuatro
    Anybody using Fram oil filters?
  15. Dec 18, 2007 at 6:54 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I do
  16. Dec 18, 2007 at 7:00 PM
    TacoSupreme
    Any specific advantages to using particular filters? Performance, Cost, etc...
    I've been using Fram for over 15yrs and never had any problems.
  17. Dec 18, 2007 at 7:03 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    ?....I've always used fram without any issues.
  18. Dec 18, 2007 at 7:49 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I run nothing but Amsoil oil and filters.
  19. Dec 22, 2007 at 3:26 PM
    sako243
    sako243 Active Member
    pennsylvaina
    2008 taco 4x4 off road v6
    scangaugell, bug deflector,
    have any of the memberes everyheard of the web site bobistheoilguy.com. he ran test on all the most popular iol and filters you will be amased at the test resultes.k&n was the worst and amsoil did not fair well in the timkin test.but believe it or not val durablend out preformed all oils even syntech. in that test
  20. Dec 22, 2007 at 4:02 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Thanks sako243,sounds like an interesting site to chek out,just the name makes it sound unbiased,I`ll have to give it a look.
