Oil filter recommendation since TRD filter discontinued
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chukar Chaser, May 2, 2024.
  1. Feb 9, 2025 at 1:04 PM
    #101
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Wow, the Amsoil filter is rated #1. Imagine that!!! :facepalm:
    MGMDesertTaco likes this.
  2. Feb 9, 2025 at 1:18 PM
    #102
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    I’m sticking with OEM filters. They are priced right and I buy 4 or 5 at a time from the dealer. Not going to mention my oil brand, don’t want to start an oil thread debate, lol.
    69 Jim, VE7OSR and t0p_d0g like this.
  3. Feb 9, 2025 at 2:03 PM
    #103
    DavidSmothers
    DavidSmothers Well-Known Member
    David
    Olive Branch MS
    2021 Tacoma TRD SPORT
    No it’s #2
  4. Feb 9, 2025 at 2:16 PM
    #104
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I heard you can put a used filter in the microwave and if it sparks then you know there is metal shavings in the oil
    BoomerGVNG, koditten and t0p_d0g like this.
  5. Feb 9, 2025 at 2:21 PM
    #105
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Side effects may include smelly kitchen, tripped circuit breaker, and divorce.
    Barsoom, IrishRed, soundman98 and 2 others like this.
  6. Feb 9, 2025 at 2:23 PM
    #106
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I have never heard that before but I can see how that would work with the element filters.
  7. Feb 10, 2025 at 6:15 AM
    #107
    Sungod
    Sungod Well-Known Member
    St Augustine
    Totally agree. I get the feeling that people think that every drop is ran through this filter continually removing every speck of particles.
  8. Feb 10, 2025 at 6:16 AM
    #108
    Sungod
    St Augustine
    Explain to me why this chart has any relevance at all.
  9. Feb 10, 2025 at 6:30 AM
    #109
    dryheat
    dryheat Well-Known Member
    I asked him and nothing but crickets. Maybe you can share what convinced you that this is the case?
  10. Feb 10, 2025 at 11:54 AM
    #110
    DavidSmothers
    David
    Olive Branch MS
    There are many tests done by 3rd parties with scientific data that shows there are clear differences between filters.
    If you go to the parts store to choose a filter and did so based on speculation then you are not making a good decision IMO.
    With a little bit of reading and research you can find that some of the filters do a better job than others
    So why not purchase a top 5 filter or a top 10?
    Why purchase a filter that ranks at #16 or #18 because you’ve always used that filter??
    No matter whose list you read about all of these filters stay in about the same place.
    Amsoil is always top 3 or 4 but not readily available
    Purolator is the same but can be found locally
    The top Fram is super easy to get and priced better
    So why buy a Toyota filter because it’s cheap?
    If price is your only concern there are better alternatives for the same money.
    And if you truly don’t care don’t take the time to read anything and throw any filter in there and go, but I paid too much for my truck to not make more of an educated decision when I do service to any of my vehicles.
    Williston likes this.
  11. Feb 10, 2025 at 12:23 PM
    #111
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    My thought is over filtration reduces oil flow which can cause oil starvation and damage your engine.
  12. Feb 10, 2025 at 12:32 PM
    #112
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    This has been solved for probably 50 years with a bypass valve in the filter. And the only way it would even reach the threshold of oil bypass is high throttle, high flow and a dirty filter
  13. Feb 10, 2025 at 12:47 PM
    #113
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    The bypass valve is a safety mechanism that allows oil to bypass the filter and flow directly to the engine when the filter becomes too clogged or over filtration which reduces oil flow. As long as you have a filter that flows well with clean oil the bypass valve will never open. You are way overthinking oil filters just change your oil on time and replace the filter with a OEM filter.
    SmoPo16 likes this.
  14. Feb 10, 2025 at 12:53 PM
    #114
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I see a lot of picky drivers but not many picky toyota engines. These things will run on whatever. That's the point of a everyday general use vehicle.
    Your truck is not special
    Your truck is not a beautiful and unique snowflake
    It is the same decaying organic matter as everything else
    t0p_d0g likes this.
  15. Feb 10, 2025 at 2:07 PM
    #115
    Buck Henry
    I think its a safe bet that bro doesn't work in Marketing. :rofl:
    pdxTacoSR5 and Barsoom like this.
  16. Feb 10, 2025 at 2:35 PM
    #116
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    20+ years as a technician ;)
    t0p_d0g likes this.
  17. Feb 10, 2025 at 3:43 PM
    #117
    InThePlains
    InThePlains Well-Known Member
    I've never heard of Toyota oil filter failure, but I have heard about oil sludge due to lack of oil change.
    Barsoom and t0p_d0g like this.
  18. Feb 10, 2025 at 4:21 PM
    #118
    dryheat
    So "feelings"
  19. Feb 10, 2025 at 4:48 PM
    #119
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Pick the same OEM Toyota oil filter that came on the truck that was on it from the factory assembly-line and call it a day.
    Over a quarter of a million Toyota vehicles came with some flavor of one in 2024, and I don't remember reading about any catastrophic mass failure reports at Toyota related to oil filters on their engines. Not even here on TacomaWorld.
    Approximately 1-million vehicles with oil-filters since 2021: I think that would have made the news: :proposetoast:
    https://pressroom.toyota.com/toyota-motor-north-america-reports-2024-u-s-sales-results/
    bmg88201 and t0p_d0g like this.
  20. Feb 10, 2025 at 5:50 PM
    #120
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    I don't have any data to support my thought process either way. I want to believe the sky is green, and most here are too busy hunting for empirical evidence that it's blue. I don't care if I'm right or wrong to the rest of the world, it's just where my thought process has led me.
    A lot of it boils down to basic physics for me.
    Placing any material in the way of the flow of a liquid, and the liquid will resist going through it. That makes for less flow after the medium. That leaves two options. Pressurize that liquid enough, it will go through the medium or boil itself off. Or there's the bypass valve that opens up once pressure gets to be too much.
    These Trucks aren't vaporizing their oil supply, no one's looking into adding oil cooler capacity, or adding misters to the existing coolers to increase the skin effect, so ultra high pressures and heat also get taken out as potentials. That leaves two options. Either the filter medium isn't a very fine filter-- to reduce restrictions, or the bypass valve is supplementing the overall system pressure.
    That's what leaves me to suspect that for every 100% of oil that runs through the oil filter, 50% or more could be bypassing every 'rotation'. Meaning that only part of the oil is filtered at any given time. But if it takes 5 minutes to fully cycle through, it's still very feasible that 100% of the oil is filtered over the course of a 30 minute drive, just not all in one instance.
    Typical physics easily shows that a good filter has terrible flow. While a terrible filter has excellent flow.
    But there's a reason every single filter has a spring in it-- even terrible filters that have minimal restrictions. And I like to think that the design engineers behind oil filters are using it to adjust and maintain overall system pressure.
    That said, I was on a performance car forum for about 8 years. Many members there were running their vehicles on a track, for multiple hours on end near redline, some even having oil starvation issues due to g-forces in corners, many with annual tire budgets that exceeded a new Tacoma's MSRP. And none of those people ever dove into oil filters as much as this mid-sized consumer-grade truck forum has.
    Vitamins, dryheat[QUOTED] and t0p_d0g like this.
