Oil filter recommendation since TRD filter discontinued
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chukar Chaser, May 2, 2024.
  1. Feb 10, 2025 at 6:13 PM
    #121
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Actually no. The bypass valve opens quite often when the oil isn't at operating temps even with a clean filter. That's because oil viscosity differs by two orders of magnitude between cold and operating temp. This also means Amsoil putting a red O-ring on the center tube is an utter waste.
    koditten likes this.
  2. Feb 10, 2025 at 6:59 PM
    #122
    dryheat
    dryheat Well-Known Member
    Thanks for responding. I don't have an opinion either way but appreciate when people back up their opinions even if it's anecdotal.
  3. Feb 10, 2025 at 7:33 PM
    #123
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    It's my understanding the number listed on a filter's spec sheet for the bypass valve isn't oil pressure, but the difference between in and out pressure. Cold oil in will be cold oil out and as long as the media isn't clogged the valve isn't bypassed.
  4. Feb 10, 2025 at 7:41 PM
    #124
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The much higher oil viscosity when the oil is cold generates much higher pressure given the same restriction.
  5. Feb 10, 2025 at 7:46 PM
    #125
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
    Correct but if the media isn't clogged as long as the delta between inlet and outlet pressure doesn't exceed what the bypass specifications are it isn't going to open. It doesn't care what the oil pressure is, just what the differences are between inlet and outlet.
    Barsoom likes this.
  6. Feb 10, 2025 at 7:56 PM
    #126
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Meanwhile the frame will rust out long before the engine fails from "lack of cold start lubrication"
    Barsoom likes this.
  7. Feb 10, 2025 at 9:03 PM
    #127
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The delta between inlet and outlet pressure can exceed bypass opening pressure when the oil is cold (and therefore thicker) at high flow rate situations (higher rpms).
    Who said anything about lack of cold start lubrication? The oil will keep flowing through the bypass valve.
  8. Feb 10, 2025 at 9:35 PM
    #128
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    As a Service Manager for a heavy equipment company, this might be the funniest troubleshooting tip I've heard in a very long time.
    soundman98 and Taco_mike73 like this.
  9. Feb 11, 2025 at 4:38 AM
    #129
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Wow, oil filter in the microwave. I’m hoping someone would try that and video the event. I’d like to see, not so much what the filter does but what the microwave looks like after the event. Come on, someone belly up and try it, I double dog dare ya.
  10. Feb 13, 2025 at 6:31 AM
    #130
    Diffident
    Diffident Well-Known Member
    Maryland
    2018 Blazing Blue SR5 DCLB
    I have a 30 year old microwave stored away in my "junk" room that I could use. I just don't have an old filter. Are we talking paper filter or canister type....the metal canister wouldn't be good. :rofl:
    bmg88201[QUOTED] and Barsoom like this.
  11. Feb 13, 2025 at 6:56 AM
    #131
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    I think the type of person that buys one new car every 15 years might be a little bit more concerned about longevity than the type of person that can consume $50,000 in tires every year as just a hobby expense.
    I also think you can do fine with the fram filters at Walmart too.
  12. Feb 13, 2025 at 7:03 AM
    #132
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes ;)
  13. Feb 13, 2025 at 11:01 AM
    #133
    bmg88201
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Yes a paper filter. I wouldn’t do it in house though, lol. I bet that would smell like a wet donkey.
    Barsoom and Diffident[QUOTED] like this.
  14. Feb 13, 2025 at 11:55 AM
    #134
    Diffident
    Maryland
    I have new filters...I could submerge one in old oil and sacrifice it for science. :D
  15. Mar 17, 2025 at 12:59 PM
    #135
    DougInNorthGA
    DougInNorthGA Member
    Northeast Georgia
    2018 Taco Off-Road 4xMT+2Lo
    Fine mesh grille w/ TRD in dark red, JDT TSS holder, plastidipped emblems, WeatherTech rain and rock guards, LEDs, 5G signal booster. 2Lo just needs a switch.
    Agreed. PurolatorONE PL25608 in my 2018 v6 TRD OR... for the filtration rating. As I've seen it said... being 99% down to 17 microns. The BOSS is rated for more miles because it allows larger debris to pass through. I would luv to see the one YouTuber add PurolatorONE to his test. Someone has a black/red screenshot of the results with the PurolatorBOSS in the 4 on everything. I want to see the ONE's hot/cold PSI ratings.
