Oil Filter relocation Kit 97 4 cyl
Discussion in '1st Gen. Tacomas (1995-2004)' started by Karlg, Sep 10, 2008.
  1. Sep 10, 2008 at 12:05 PM
    Karlg
    Karlg [OP] New Member
    Houston Tx
    97 Tacoma Lx 2.4L
    Does anyone know about or done an Oil Filter housing extension/relocation kit. Pretty tough at my age to reach filter from side or even from below:confused:
  2. Sep 10, 2008 at 1:28 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    umm I would be intersting in this as well...
    Heck, if this could be worked to have an Oil cooler as well it would be even better...
  3. Sep 10, 2008 at 7:38 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Here are some pros & cons of doing this.....
    http://www.yotatech.com/f2/oil-filter-relocation-kit-29094/#post278673
    It's a real pain to do oil changes on these trucks I know, & a long time ago, I thought about getting a kit for my truck. I did some reading on this and it kinda scared me that while driving, sometimes the clamps can pop off from just the heat of the oil:eek:.....If you do get one, it might be a good idea to get the heavy duty fittings & braided lines. Hope this helps..... Good luck! :D
  4. Sep 11, 2008 at 8:57 AM
    ubermx5
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Well about hoses...
    You can get great hose at the hole reman shops. They can sell you stuff that can with stand oil, heat and anything else..
    Also getting the right clamps is key to any project like this.
    If you could, see about having the hoseman making the end of the hose pressure clammed. like for Power sterring.
    If you get a hose that can with stand 5000 PSI then you are golden.. that also work with OIL, GAS, and other toxic stuff you will not have an issue. Or you should not.
    SO that post said look at Ford kits..
    I guess take a Toyota filter in and see if it matchs.
    Does any one have feed back on addingin larger filters and is it an issue.
    I know they make monster fitters these days.. You know waht you find aon Ford 302 block from the 1969
  5. Jun 14, 2009 at 4:48 PM
    AKTaco
    AKTaco New Member
    Alaska
    TRD Limited
    deck plate mod
    I ran this for years on a cherokee. Get hoses rated as fuel line and you will be fine. A normal rubber hose will sweat oil over time and make a mess. Never had an issue with leaks using regular old hose clamps. Getting the ends crimped on would all but eliminate any issues. Thinking of doing thins on a '02 3.4L......
  6. Jul 17, 2009 at 7:06 AM
    opc167
    opc167 Active Member
    Macon Georgia
    96 4x4 3.4L XL
    I've only opened up the air box for more air intake. No mods.
    Does it have an issue if the filter kit is mounted on the side of the wheel well?
  7. Jul 17, 2009 at 7:10 AM
    opc167
    Macon Georgia
    96 4x4 3.4L XL
    I forgot to ask, can a oil cooler be mounted using a second fan if you don't want it installed around the radiator? I'm using an electric fan for the radiator and thought if the oil cooler had it's own fan, it would cool all the time while the truck is running.
    Thanks
