Oil filter relocation kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrp192, Mar 17, 2011.
  1. Mar 17, 2011 at 1:39 PM
    mrp192
    mrp192 [OP] REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    Has anyone done an oil filter relocation? If so where did you get it?
    I was changing my oil yesterday and the filter is a pain in the ass.. I even had the truck on a lift and the old filter was a K&N filter that has the 1" bolt on the end... Changing the filter took the longest!
    Last week I changed the oil in my Xterra and it took me 30mins! it took me a hour to do the truck. Both times include getting the truck on the lift and taking off the skid plates and what not..
  2. Mar 17, 2011 at 1:45 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    I have one on my Tacoma, makes changing the oil a very easy process, filter was relocated to the left front fenderwel. It was on the truck when I bought it. So I can not help you, where to locate one.
  3. Mar 17, 2011 at 1:48 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Ive had the same difficulties changing my oil too. It was located under the left front fender. It was so tight on there that i couldnt even turn it with a filter clamp let alone my own hand! I ended up punching the side of the filter with a long screw driver to turn it. What a pain!! But after i did it someone told me you can just take off the skid plate and you get way better access to it!
  4. Mar 17, 2011 at 2:09 PM
    mrp192
    Brent
    Cheney WA
    Can you post a pic?
  5. Mar 17, 2011 at 2:10 PM
    mrp192
    Brent
    Cheney WA
    even if its just getting pointed in the right direction on the right parts to get... I have a area that i want to mount mine.
  6. Mar 17, 2011 at 2:26 PM
    Jdaniel1274
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    I do not have a digital camera, but can send you some pictures via text message if you like. Just pm me your cell phone number.
  7. Mar 17, 2011 at 2:51 PM
    Jdaniel1274
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    Colchicine likes this.
  8. Mar 17, 2011 at 2:55 PM
    mrp192
    Brent
    Cheney WA
  9. Mar 17, 2011 at 9:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I need to do this.
  10. Mar 18, 2011 at 2:03 AM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Yeah you're supposed to take off the skidplate, makes the job easy. Is it just me or is changing the oil filter not that big of a deal. Being a mechanic and seeing so many different vehicles, the 3.4's oil filter is about average, it's no big deal so long as you take off the skidplate. There are WAAAYYY worse designs that will make you slap yourself for complaining lol.
  11. Mar 18, 2011 at 5:19 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    make sure you use a good metal braided hose ....the hoses that come in those kits have been known to leak.
    burntkat likes this.
  12. Mar 18, 2011 at 5:51 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    I had the relocation kit on my Tacoma for over 100K!
    It worked great and made oil changes a snap - no more skid plate removal.
    I just took it off since the gasket between the block off plate and the engine block developed at leak.
    It WILL be being put back on at the next oil change!
    I used rubber lines and never had any issues.
  13. Mar 18, 2011 at 7:03 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    i dont find it hard at all to get to just turn your wheels left and remove the rubber guard inside the driver side wheel well and theres the filter easy to get to and take off takes me 30-40 mins tops.
    Ngneer likes this.
  14. Mar 18, 2011 at 10:05 PM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    whoah.... what's all this "remove the skid plate" B.S.?
    I have yet to remove a skid plate to gain access to my oil filter.
    Haven't heard of such talk since the old days of apartment living & instant oil change shops. "oh, we're gonna probably hafta remove the skid plate to get your filter off - that'll be an extra charge for that"... f'n horseshit!
    3.4L is not that tough to remove the filter - it's just messy. Because of the angle you (I) seem to dump half of the contents of the filter down onto the skid plate.
    I'm not trying to be a prick, it's late & I'm drinkin'.
    Sorry if I offend, but seriously - removing the skid plate is making it way harder than it needs to be. :cheers:
  15. Mar 18, 2011 at 10:59 PM
    kumaWRX
    Jase
    Oahu, Hawaii
    I didn't say that you have to remove the skid plate to gain access, its to make the job easier and faster b/c of way less cleanup. We do not charge extra to remove the skidplate, which is only six 12 mm bolts and which only takes like 30 seconds to remove and it benefits us b/c its much cleaner and we waste a lot less brakeclean.
  16. Mar 19, 2011 at 5:37 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I would say Toyota missed the mark on the oil filter, while no better or worse than many as to location, who designed it so that you can't but spill oil all over whether you take the skid plate off or not. A straight up and down adapter would be an instant hit in the 3.4 community I think.
    frenchee and whoareyou133 like this.
  17. Mar 19, 2011 at 12:23 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    x2 isnt hardly anything for our trucks, but when you get the ones like a 240 where its under the header those are a PITA and takin the skid plate off is a 1 minute job with a cordless impact or even a drill :D
  18. Mar 19, 2011 at 8:28 PM
    mrp192
    Brent
    Cheney WA
    well im fucking 5'4" 5'5" so eveything is fucking hard for me!
    na i would just like it to be easier then what it is now.. I swear its easier to change the filter on the F-22..
  19. Mar 20, 2011 at 8:55 AM
    OmahaStylee
    Omaha, NE
    01 DC TRD
    i'm sober now :D sorry if I was a dick earlier...
    reading through these posts got me thinkin' - with the comment about being short (my dad is about same height),
    I'm always reaching down from top, standing in front of the truck. I know right where to find the filter & there's a narrow passage way that just feels familiar every time.
    It just occurred to me that the instant oil change shops do a lot of their work from below (something I'm not used to -
    the only thing I get down there for is the drain plug). I guess it's just a matter of perspective - the flow of your oil change routine that you're accustomed to.
    For me, someone who does most of the work topside, it would be more time & effort to remove the skidplate than it's worth.
    I have considered the filter relocation kit just for the soul purpose of keeping things clean under there.
    I ALWAYS end up dumping about half the filter's capacity due to the angle that it sits. :facepalm:
  20. Mar 20, 2011 at 11:58 AM
    mrp192
    Brent
    Cheney WA
    dude dont worry about it i was fucking with you....
