Oil Filter Removal Tool?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kahanabob, Jan 15, 2025.
  1. Jan 20, 2025 at 5:43 AM
    #41
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Absolutely BEST bet around for oil changes:
    1. - Get the Fumoto drain valve, cap and tube extension (I forget what the basic valve comes with) ESPECIALLY if you have a Pro skid.
    2. - Get the MotivX oil drain kit
    Install both, and it will make oil changes substantially easier, and a whole lot less messy.
    I only attempted an oil change 1 time prior to installing the Fumoto valve and MotiveX kit, never again......
    As others have said, a very light tap on the oil wrench, or just back it off a C-hair and it will slip right off.
  2. Jan 20, 2025 at 1:49 PM
    #42
    Trd OR
    Trd OR Well-Known Member
    Bay
    21 tacoma
    Thx for the feedback
  3. Jan 20, 2025 at 6:09 PM
    #43
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    adding on, i just ordered the aluminum filter housing.
    So do i finger a little oil on the threads and O ring before installing?
    maybe dumb ?
  4. Jan 20, 2025 at 6:31 PM
    #44
    woollypullover
    woollypullover Well-Known Member
    2019 Tacoma Sport
    I use el cheapo aluminum one. Mines only gotten stuck when it was positioned upside down. I don’t really bother cleaning off the old oil and now I carefully seat the tool before turning a wrench. No problems.
  5. Jan 20, 2025 at 6:49 PM
    #45
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    o rings
    I wouldn't do threads
  6. Jan 30, 2025 at 11:49 AM
    #46
    woollypullover
    2019 Tacoma Sport
    Not saying some form of anti seize or oil is bad but it will mess up the torque if you are using a torque wrench. Antiseize or oil is not at all necessary on the stock filter housing, aluminum who knows?
    If you aren’t using a torque wrench just seat the parts don’t wrench down hard at all.
  7. Jan 30, 2025 at 4:32 PM
    #47
    InThePlains
    InThePlains Well-Known Member
    Either use a vampire pump or collect from the drain mid flow.
    Taco_mike73[QUOTED] likes this.
  8. Jan 30, 2025 at 4:38 PM
    #48
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yes on both. Don't want aluminum threading into aluminum dry, if you plan to loosen it again.
  9. Jan 30, 2025 at 5:18 PM
    #49
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Good thing I don't torque mine!
    I always oil the o-ring. Makes everything slide in together better
    TacoTime55 likes this.
  10. Jan 30, 2025 at 6:08 PM
    #50
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I collect in mid flow. What I was getting at with the Fumoto valve is you have control over the flow, you can easily stop it more so than you can if you just have a drain plug. putting it back while the oil is flowing would be messy
  11. Jan 31, 2025 at 10:25 AM
    #51
    kahanabob
    Maui
    16 TRD 2WD 4DR
    That is my exact thoughts, thanks
    t0p_d0g likes this.
  12. Jan 31, 2025 at 10:48 AM
    #52
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Hand-tighten mine upon replacing filter.
    Use removal tool on next oil change.
    Not as difficult to unscrew the housing unit once pre-draining is complete. I'll have to take a pic with the Aluminum Hosing.
