Oil filter removal: what do you guys use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Iowa10, Apr 2, 2017.
  1. Apr 2, 2017 at 1:30 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
  2. Apr 2, 2017 at 6:56 PM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    tacomavoyager[QUOTED] likes this.
  3. Apr 2, 2017 at 9:06 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    You can use these Strap Wrenches for your oil filters; I like them a lot more than the tools suggested here.
  4. Apr 2, 2017 at 9:11 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I dunno it has always worked for me.
  5. Apr 3, 2017 at 12:53 AM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    all I know is trying to find a wrench that says in the description for a Tacoma is nearly impossible, labels every other Toyota vehical but not Tacoma.
    I assume its 24mm x 64.5 mm with 14 flutes?
  6. Apr 3, 2017 at 2:21 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I use my hand to install, but an old set of oil filter pliers to remove. It damages the filter a bit, but I am taking it off to change it anyways.
    Similar to these:
    JimboAnz likes this.
  7. Apr 3, 2017 at 3:51 AM
    NM Lance
    NM Lance Well-Known Member
    I have to use the steel band/strap type. Arthritis has gotten the better of my hand strength.
  8. Apr 3, 2017 at 3:53 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I have found this to be best for me
  9. Apr 3, 2017 at 10:35 AM
    MethodMan
    MethodMan Well-Known Member
    DCLB TRD Sport
    OME 885s, Dakar leafs, Cooper ST Maxx Tires, TRD Baja wheels, TRD Pro grille
    (For the V6) its pretty much as easy as it gets. You shouldn't need any tools on this one.
  10. Apr 3, 2017 at 10:40 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Or, if youve already drained the oil to then find your filter is stuck with no tool. Just drive a flat head screw driver through the side of the filter.
    It's gotten me out of a bind before.
    1Shifter likes this.
  11. Apr 10, 2017 at 4:07 PM
    Rosa Klebb
    Rosa Klebb Member
    Tucson, AZ
    2012 4X4 Access Cab
    Still Thinking ? ? ?
  12. Apr 10, 2017 at 4:17 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    When I used to have the dealer change my oil ( free oil changes) , I could never get the oil filter off by hand, but once I started changing my own oil, it just hand tighten, and I can take it off by hand the next time I change my oil.
    OP, just make sure you're using a twisting action for the oil filter (unlike the "other" motion you're probably used to. Lol)
  13. Apr 10, 2017 at 4:23 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    I use one of these for my 2008 (or daughters 2012) Tacoma.
    ....and I use this when changing the oil filter on my wifes 2016 4Runner (removed the original black one for an all aluminum type as shown)
    TomTwo and TACO TX like this.
  14. Apr 10, 2017 at 4:55 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    I also use my hand. Sometimes I put it on a little tight and it's a struggle, but I can always get it by hand. The first time I changed it myself I had to use a set of tube clamps. The dealer had out the filter on tight and it's a long ways up in there on the 4 cyl. My tube clamps were handy so I used those.
  15. Apr 11, 2017 at 12:57 AM
    #35
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When did you shave?
    :eek:
    jackn7 likes this.
  16. Apr 11, 2017 at 3:01 AM
    #36
    airrage
    Myrtle Beach, SC
    I have a better chance of finding the Holy Grail then a Wrench cap to fit the Tacoma oil filter. No matter what I look for on Amazon or ebay, in the description not one will say fits 2nd gen Tacoma. All I get is 2016 Tacoma or every other Toyota vehical made. Somebody prove me wrong please. This is what I am looking for something like this, https://www.amazon.com/dp/B00XTAGHU0/ref=pd_luc_rh_bxgy_01_02_t_ttl_lh?_encoding=UTF8&psc=1
    #36
  17. Apr 11, 2017 at 3:32 AM
    #37
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    + another. I had a cap wrench that fit at one but lost it. All I use now is hand for all my vehicles.
  18. Apr 11, 2017 at 3:56 AM
    #38
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Tighten with my hand and usually can remove the same way...sometimes need a strap to get it started.
  19. Apr 11, 2017 at 4:36 AM
    #39
    Sword5
    Sword5 Member
    Randy
    Lexington, Ky
    2006 Tacoma TRD
    Lund 5" nerf bars, weathertech rain guards, Depo led tail light replacements, Anzo led 3rd brake light
    My hand, unless for some reason someone else has done it. The dealers are the worst for either putting them on tight or too loose.
  20. Apr 11, 2017 at 5:52 AM
    #40
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Im surprised this hasnt been posted yet. I use a channel lock filter wrench when i cant get one off by hand
    Edited to add. Didnt read far enough, its on here already lol
