Oil Filter Removal Without Making a Mess
Discussion in '1st Gen. Tacomas (1995-2004)' started by bwise, Feb 24, 2025.
  1. Feb 24, 2025 at 3:32 PM
    bwise
    bwise [OP] Well-Known Member
    3.4 L V6. Oil change this weekend. Every time I've done it in the past when I take off the oil filter it spills oil everywhere. I go in through the drive side wheel well.
    I follow what's laid out on this thread - https://www.tacomaworld.com/threads/3-4l-5vz-1st-gen-oil-change-guide.48136/
    I saw on there that cutting a 2 Liter bottle about 4 inches from the bottom works for catching oil.
    If this a good strategy? Anyone else do anything special to mitigate this mess?
  2. Feb 24, 2025 at 3:43 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Poke a hole and drain it. I put cardboard down before I change fluids, then spray off whatever drips with carb cleaner.
  3. Feb 24, 2025 at 3:49 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Can always use a Quart plastic milk jug with the bottom cut out, loosen and catch the drippings and filter.
    MadNachos likes this.
  4. Feb 24, 2025 at 4:31 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    You can get moldable 'funnels' that work well for odd stuff. I just use some brake cleaner when done.
  5. Feb 25, 2025 at 4:17 AM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    stuff some shop rags everywhere it will be dripping :notsure:
    gravity sure is a MF!
    Moonrman likes this.
  6. Feb 25, 2025 at 6:57 AM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    It's a mess for sure, I pull my skid plate when I do an oil & filter change and always plan a trip to the closest car wash pretty quick afterwards. I'd rather spray the bottom of my engine with water than leave the oil. Also with the skid plate off I can have a look see about any other potential problems.
    skeezix likes this.
  7. Feb 25, 2025 at 8:43 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I just wrap the oil filter in a heavy-duty trash bag while I’m taking it off, easy-peezy and no drips!
    skeezix, Corvax and MadNachos like this.
