Oil filter=Ruff Idle...Say What??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mugs, Dec 4, 2019.
  1. Dec 5, 2019 at 1:42 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Is there any chance you could provide the equivalent .pdf document for the 2TR-FE engine?
    Or maybe a link to the source (if it is available to the public)?
    Thanks!!
    FYI, my engine is a 2017. I don't suspect any difference.
  2. Dec 5, 2019 at 1:49 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I found the V6 document in the forum and saved it. It is possible that there is a I4 document in here somewhere. It might be in the second gen as I believe the engine is a carry over.
    shakerhood likes this.
  3. Dec 5, 2019 at 2:09 PM
    TartanEagle
    '17 ACLB 4x4 MT
    @Speedfreak I'll go looking. Thanks for that info.
    Speedfreak likes this.
  4. Dec 5, 2019 at 2:15 PM
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    As the thread title says...
  5. Dec 9, 2019 at 7:23 AM
    Mugs
    Mugs [OP] Well-Known Member
    Doug
    Pacific North-Wet
    2019 Tacoma TRD Off-Road
    Nitro Gear 5.29's, ARB locker, 3in OME Lift, ARB Leaf Springs, TRD Rims, Nitto Ridge Grapler 285/75/17, TRD skid Plate, CBI Rock Sliders, , ARB Compressor. Total Chaos bed stiffeners. Lots more to come.
    Thank you all thus far for your replies. After having read the PDF of the fuel system cleaning, I'm still not thoroughly convince that it was just the fuel cleaning cycle. Unless the cleaning cycle does it at every single stop. It may have compounded the issue, but not the issue entirely. Plus it wouldn't explain why the symptoms went away with the oil change. For now I'll just keep monitoring.
  6. Dec 9, 2019 at 7:37 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    The cleaning cycle is based on the type of driving demand. If you drive where the the direct injection system is primarily used then the cleaning cycle will be more frequent. In my experience, the cleaning cycle comes on for a varied amount of time at 95% of stops.
    Now if you did have another issue that clearly disappeared after you changed the oil filter, then maybe you had a bad filter. It isn't impossible. I have put brand new filters on at work that had pin holes in them and then drew air into the diesel injection system. Then you are left scratching your head trying to figure out the poor power after a service.
    I have used Fram and Mobil 1 filters in my truck with zero issues or complaint.
    shakerhood and Mugs[QUOTED][OP] like this.
  7. Dec 12, 2019 at 6:38 PM
    Timbertoy
    Timbertoy Well-Known Member
    Wayne
    2019 Red Tacoma
    Just reaching out with a thought, you stated when it got colder the rough idle stopped. The Tacoma’s run a little rougher with the A/C running. Could smoother idle in colder weather be due to A/C not on?
  8. Dec 12, 2019 at 7:09 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    No, it has to do with fuel delivery - direct, port or either.
  9. Dec 12, 2019 at 7:13 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    And what parameters does the ECU use to determine cleaning vs Port injection?
  10. Dec 12, 2019 at 7:17 PM
    Vlady
    Issy, WA
    Temps- intake, coolant- for sure.
    I observe startup is always port, then depends on engine load and speed it would call for direct or either.
  11. Dec 12, 2019 at 7:19 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    So colder ambient could affect cleaning?
  12. Dec 12, 2019 at 7:25 PM
    Vlady
    Issy, WA
    Yes. On these truck lots of things are linked to the coolant temp.
  13. Dec 12, 2019 at 7:29 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Wait :confused:
  14. Dec 12, 2019 at 7:33 PM
    Vlady
    Issy, WA
    You were suggesting that a/c status was playing a role.
    "...Could smoother idle in colder weather be due to A/C not on?"
    What do you think is a coolant?
  15. Dec 13, 2019 at 2:03 AM
    #35
    Timbertoy
    Wayne
    2019 Red Tacoma
    I sir was only suggesting a path or possibility. That’s what this is all about.
    My past experience has shown this to be true.
  16. Dec 15, 2019 at 1:11 PM
    #36
    Mugs
    Doug
    Pacific North-Wet
    No I don't think this has anything to do with it, I tested it both A/C off and on, and the symptoms still continued to be the same. Also with the colder temps, and high moisture content in the air where I live, I have the foot/de-frost setting on 95% of the time. Which still activates the A/C cycle because of the setting being on de-frost. I did think about this at first/ I change the oil again this weekend using OEM filter and my usual 0-20 Castrol Magnatec oil. Will continue to monitor and see what happens in a few months with the weather begins to heat up again.
