Oil filter unused when doing the oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Htc-taco15, Jul 1, 2019.
  1. Jul 2, 2019 at 5:04 PM
    #101
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Well done!:cheers:
    Blue92[QUOTED] likes this.
  2. Jul 2, 2019 at 5:04 PM
    #102
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Why don’t you just decide in your mind you are right and then not waste peoples time being argumentative.
    Yes I guess if you did two oil changes one hot and one cold and let it drain for 24 hours you would get virtually the same drained.
    I don’t let mine sit for hours on end.
    The OP is changing the oil when cold so the oil will be drained out of the filter.
  3. Jul 2, 2019 at 5:06 PM
    #103
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I could say the exact same thing to you, pal.
    Neither do I, sits for 15 minutes tops to get everything out.
    ace96, ilovich and vssman like this.
  4. Jul 2, 2019 at 5:09 PM
    #104
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Man your lucky. I keep putting gas in my truck, but the tank always seems empty.
    Tullie D, b_r_o and Blue92 like this.
  5. Jul 2, 2019 at 5:10 PM
    #105
    lynyrd3
    Bill
    East Central Upstate NY
    :worthless:
    b_r_o likes this.
  6. Jul 2, 2019 at 5:20 PM
    #106
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Ahhh the good old days. If you didn't like an oil filter, just leave it out and change oil every 1,500-2,000 miles
    b_r_o likes this.
  7. Jul 2, 2019 at 6:19 PM
    #107
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    When you remove the old oil filter, everything visible to the eye looks fine. You can't see dirty media. You see shiny metal, a nice gasket, nothing different other than it is oily vs brand new filter.
    Maybe that is what the OP is reporting?
    mojojojo78 likes this.
  8. Jul 2, 2019 at 6:42 PM
    #108
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Also having a Fumoto valve makes it a dream. :rofl:
    xxTacocaTxx and Toywoodsguy82 like this.
  9. Jul 2, 2019 at 6:46 PM
    #109
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I aint that trustworthy. A good old 14mm is pretty failsafe.
    Granted, Ive never heard of someone loosing all their oil cause a valve came undone. But I dont want to be the first.
    SR-71A and Extra Hard Taco like this.
  10. Jul 2, 2019 at 7:04 PM
    #110
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    They have a safety clip... works good too...
    SC4333 likes this.
  11. Jul 2, 2019 at 7:04 PM
    #111
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Makes the oil drain slower but that's not the only reason I don't use them. I won't trust a valve with my engine's critical life flowing fluid. While Fumotos have a pretty good reputation there has been horror stories. Not many where the oil drained out quickly but some have been reported to leak.
    I'll stick to my good ol fashioned trusty magnetic drain plug. Not like it's hard to remove & replace a drain plug anyway. I've considered putting one on some of the machines in my garage but I'll never put one on a vehicle that I own & love. But that's just me.
    Extra Hard Taco, BillsSR5 and Blue92 like this.
  12. Jul 2, 2019 at 7:07 PM
    #112
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Im sure it does. But I still dont trust it. I see I share the same opinion with @zero4.
    Extra Hard Taco and zero4 like this.
  13. Jul 2, 2019 at 7:11 PM
    #113
    Wulf
    rock raisin
    The Thai one comes with a surprise package
    Paul631 and Tacosail like this.
  14. Jul 2, 2019 at 7:19 PM
    #114
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yep if Thai they're known for looks to be deceiving! Pretty sure it might have something hanging out rather than a hole where you screw it in. ;)
  15. Jul 2, 2019 at 7:21 PM
    #115
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I’ll have you know, I’ve been running without an oil filter for the last 3 years. Zero problems!
  16. Jul 2, 2019 at 7:31 PM
    #116
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Been running one for 2yrs now, zero issues. I like it.
    Toywoodsguy82 likes this.
  17. Jul 2, 2019 at 7:33 PM
    #117
    Toywoodsguy82
    Patrick
    Oregon
    Everyone has their likes and dislikes. I get it.
  18. Jul 2, 2019 at 7:34 PM
    #118
    Wulf
    rock raisin
    The exhaust port is practically the same though
  19. Jul 2, 2019 at 7:39 PM
    #119
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    I had one for a while it worked great, but I didn't like how low it sits and I offroad a lot. If it gets caught on a rock I'm done.
  20. Jul 2, 2019 at 7:49 PM
    #120
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The reason you warm and circulate the oil before an oil change is two fold.
    1. It allows the oil to drain faster.
    2. The oil warming up and circulating picks up more contaminates, which then get carried out when it is drained.
    It doesn't have to be or nor should it be done at full operating temperature. Just good and warm after getting circulated well through the engine.
    xxTacocaTxx and fathomblue like this.
