Oil Filter Wrench for 4 banger oil filter?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willconltd, Jan 22, 2025.
  1. Jan 22, 2025 at 12:11 PM
    willconltd
    willconltd [OP] Well-Known Member
    Orlando, Florida
    I was changing my oil the other day and the last guy who did it put the filter on too tight. I really had to struggle to get it off this time.
    The idiot was me, but I only used my hand last time.
    Searching for a filter wrench is only bringing up the 6 cylinder canister filter wrench in assorted varieties.
    Anyone got a recommendation for the regular spin on oil filters?
    Thanks!
  2. Jan 22, 2025 at 12:25 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    I like the springy spider finger one for the smaller filters that goes on the 3/8" ratchets.
    TaCoHiOgUy likes this.
  3. Jan 22, 2025 at 12:35 PM
    2020TacomaGuy
    2020TacomaGuy Well-Known Member
    2020 4x4 DCSB SR5
  4. Jan 22, 2025 at 12:38 PM
    willconltd
    Orlando, Florida
    Ok, that's a good answer. Thanks for your help.
    Ordered the filter wrench.
    I use the YZZD3, but its the same fitment as the other filters, its just taller so there is more filter material.
  5. Jan 22, 2025 at 12:42 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Nothing beats these cam style filter wrenches for the old school metal spin on filters. This tool will literally crush the outer can if the filter is stuck on there and you keep turning it.
    Barsoom and Chew like this.
  6. Jan 22, 2025 at 12:45 PM
    2020TacomaGuy
    2020 4x4 DCSB SR5
    Good choice also
  7. Jan 22, 2025 at 12:50 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Can use it for lots of other stuff also.
    I bought a set of 4 of different sizes and use them all the time.
    Each one adjusts to different sizes.
  8. Jan 22, 2025 at 1:09 PM
    661 Well-Known Member
    SoCal
    I use a cheap one like this from autozone. works perfect
  9. Jan 22, 2025 at 1:20 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I have one of these I use on my daughter’s Scion spin on filter.
    https://www.autozone.com/shop-and-g...MIuJWLoKCKiwMV4i2tBh3DpxCFEAQYBiABEgLO9_D_BwE
  10. Jan 22, 2025 at 1:34 PM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
  11. Jan 22, 2025 at 1:48 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Oh yeah, and you can even use one to hammer a screwdriver through the side of the filter, and use that to twist it off if it's super stubborn.
  12. Jan 22, 2025 at 1:55 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    No !!! to the screwdriver. I have seen the canister tear off leaving the filter base still tight as heck and now not much to hang onto...
    But if you insist, have at it...
  13. Jan 22, 2025 at 1:59 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
  14. Jan 22, 2025 at 2:01 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
    This kind of thread is also why I cringe when people use a torque wrench to install the filter; you just know it's going be hard to get off later.
  15. Jan 22, 2025 at 2:46 PM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    I use the socket type oil filter wrench like these. I got mine years ago and don't remember where I got them. Mine are actually cast Aluminum. They have worked great for me for years.
  16. Jan 22, 2025 at 2:59 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    This is what I use on the YZZD1 and it will also fit the YZZD3 it fits perfectly and has never failed…
    https://www.jtcautotools.com/product/jtc-4667
    Tacorific likes this.
  17. Jan 22, 2025 at 3:06 PM
    willconltd
    Orlando, Florida
    I already ordered the one in the third post.
    Thanks for all your responses though!
  18. Jan 24, 2025 at 2:11 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Since you’re complete, I’d just comment the gorilla who tightened the oil filter(you) has aged and lost hand strength…. Just kidding
  19. Jan 24, 2025 at 4:22 AM
    willconltd
    Orlando, Florida
    Clearly I am stronger on the concrete laying on cardboard than I am with the truck on the lift reaching over my head.
    Its the only difference I can think up.
  20. Jan 24, 2025 at 5:53 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    The heat cycles and time always make it tighter to remove. That's why if you use a wrench and torque it when putting it on, oftentimes the filter will just crush / slip in the wrench when you take it off.
    The filter should have instructions on how much to tighten, something like 1/4 to 3/4 of a turn after the gasket contacts the surface. (4.0 filter was 3/4 of a turn, which was a lot). Or if you're comfortable with it, I would tighten it as much as I could by hand (up to 3/4, but no more), then you can usually get it off with the wrench or even by hand again.
