Oil Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skipper124, Oct 7, 2013.
  1. Oct 7, 2013 at 5:28 PM
    skipper124
    skipper124 [OP] Member
    Ohio
    SR5 2.7
    Just tried my first oil change today and ran into a nasty surprise.I couldn't get the oil filter off! The dang thing is wedged between the block and frame with no room to turn an oil wrench:mad: and has half a shield on it where you can't even grab it.How do people get these things off? Is there a special too I need? Only thing I can think of is to take it to a shop and let them change my oil and tell them to hand tighten it.I cut half my wrench off but still couldn't loosen it.
  2. Oct 7, 2013 at 5:39 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Punch a screwdriver through it.
  3. Oct 7, 2013 at 5:57 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i have no problem getting a wrench on mine.
  4. Oct 7, 2013 at 5:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Use your hand covered with a plastic bag to catch the filter. From directly underneath on your back looking up use a steady pressure clockwise to loosen it. It'll come. Good luck!
  5. Oct 7, 2013 at 6:21 PM
    skipper124
    Ohio
    SR5 2.7
    Clockwise to loosen? No wonder I couldn't get it,I still have a lot of trouble getting my hand on it though with that shield covering about half of it.
  6. Oct 7, 2013 at 6:28 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    If you turn it clockwise to loosen it, you will never get it off. Please turn in a counterclockwise motion, use a filter wrench, other than that, you should just go get it changed somewhere.
  7. Oct 7, 2013 at 6:45 PM
    skipper124
    Ohio
    SR5 2.7
    That filter is much more accessible than mine,I will try to take a picture and post it,its ridiculous! I thought my old Ranger was in a bad place, but this thing takes the cake.
  8. Oct 7, 2013 at 7:02 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I felt your pain on my first oil change. I think Attila the Hun installed the oil filter at the factory. Keep at it and it will come off. I only use the K&N filter because of the 1" nut on the filter makes removal very easy.
    You might want to double up a small width of sandpaper between the filter wrench and the filter to help with the friction to take off the filter.
    Also a little tip, the K&N HP-2009 filter fits perfectly and is a larger filter than the recommended K&N filter.
    I also posted a thread asking for help. Mr. 4X4 responded to help me out.
  9. Oct 7, 2013 at 7:03 PM
    skipper124
    Ohio
    SR5 2.7
    AHHH that might be what I need right there! I need something to hang down below the suspension and frame where I got room to turn,I read where Godzilla puts these thing on at the factory so I'll need all the torque I can get
  10. Oct 7, 2013 at 8:25 PM
    skipper124
    Ohio
    SR5 2.7
    It would probably work for mine but the thing that worry's me is that stupid shield they got covering around half of it might not allow the clamps to fit over the filter,just hope there is enough clearance there.But a couple extensions down from that and I should be in business if it will get between the filter and shield.
  11. Oct 7, 2013 at 8:35 PM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    thats what i do :) makes a nice... even if a little messy, handle for you to turn even the tightest filters loose
  12. Oct 7, 2013 at 8:38 PM
    Konvict KROG
    Louisiana
    I have one of these as well, its a good tool. but i prefer the screwdriver method now. Well, i did, NOW i have a 1gr and the filter is on top, AND toyota does my oil changes :)
  13. Oct 7, 2013 at 8:41 PM
    skipper124
    Ohio
    SR5 2.7
    Do you punch a hole in the side or on the bottom?the bottom is probably the only way i could punch into it with all the crap they got surrounding it.
  14. Oct 7, 2013 at 8:48 PM
    Konvict KROG
    Louisiana
    When i had my 2.7 it was crowded as well, and i stuck it straight through the side, in on and out the other (if you only go through one side and its really over tight you mayjust make a mess, not a productive mess)
    The first time i did it, i used a hammer, but after i figured out i could do it by hand i didnt use the hammer anymore..
  15. Oct 7, 2013 at 9:05 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I so hope someone does a video on this.
  16. Oct 7, 2013 at 9:07 PM
    Konvict KROG
    Louisiana
    if i had a 2.7, i would.. happily i no longer do :)
  17. Oct 7, 2013 at 9:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Was yours vertical like the current 2.7, or sticking horizontally off of the block like the 22RE?
    I don't see how you could drive a screwdriver into the side of the filter on the current 2.7, especially not with the shield around the back.
    If I can't get mine off with a gloved hand, I use a 3-jaw Craftsman
  18. Oct 7, 2013 at 9:26 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    He only did 3 things wrong.
    1 - When he removed the oil cap, he left it on the opening.
    Place it on the hood latch. Same for the radiator cap if working on the cooling system. Do that and you will NEVER close your hood and try to drive off without A) Replacing the oil/coolant or B) Replacing the cap
    (Claremont Toyota forgot to replace my radiator cap on my 22RE)
    2 - Those drain pan/jugs make much less mess if you open the little snap-on vent... prevents the "burping" out the drain hole.
    3 - He's been lucky... the filter really does need 1/2 to 3/4 turn after contact, and it will be no harder to remove the old one. I go 3/4 to 1 turn... as far as I can get it with a gloved hand. No way I'd trust 1/4 turn. His success says a LOT for Toyota's O-ring.
  19. Oct 7, 2013 at 9:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I've seriously considered puncturing my filter just to drain it.
    Where it's positioned, when the seal breaks, the oil clears the block, so it's better than my 22RE, but it falls right on the trans cooler lines.
    I'm seriously considering a filter relocation kit, but can't find a good spot on that side of the engine bay where it would be convenient to slip a bowl under the filter before removing it.
  20. Oct 7, 2013 at 9:34 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
