Oil filter.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck93, Sep 26, 2018.
  1. Sep 26, 2018 at 3:46 PM
    tacotruck93
    tacotruck93 [OP] Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    So I'm not sure which one is the recommended oil filter it seems like every other time I go to the dealer they give me a different filter and they have my VIN number so it should give me the right one all the time. The last oil change the filter they gave me was a 90915-YZZD3 . This time when I went in to get a filter they gave me a 90915-YZZD1. The only difference that I can tell is the D1 is a little shorter.
  2. Sep 26, 2018 at 3:51 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    I can't remember the parts # from the filters I always get at the stealer, but according to Amazon, the YZZD1 does not fit your truck. The YZZD1 is for the 2.7l
  3. Sep 26, 2018 at 3:55 PM
    tacotruck93
    Zach
    Akron,Ohio
    Okay well. It's on my truck now haha. So should I go get the D3 or should it be fine for a little ?
  4. Sep 26, 2018 at 3:58 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
  5. Sep 26, 2018 at 3:59 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    The filter will fit but the 1 is what my 2.7 uses. I change often so the smaller filter is ok. If I were running higher miles between oil changes I’d run the 3.
    Size is the only difference I think.
    Maybe bypass pressure pretty sure I’m not sure about that.
  6. Sep 26, 2018 at 4:05 PM
    tacotruck93
    Zach
    Akron,Ohio
    Alright I'll be good then I only go 3-5k between changes. But I just don't see how they look my name up and still keep messing up the filter I mean he even asked what size motor to make sure. I guess I need to double check everything they give me.
  7. Sep 26, 2018 at 4:09 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yes don’t trust your dealer!
    Buy your own stuff and do as much of your own maintenance as you feel comfortable!
    Tacoma world and you tube have been huge in me knowing and maintaining my ride!
    SH7mi likes this.
  8. Sep 26, 2018 at 4:13 PM
    tacotruck93
    Zach
    Akron,Ohio
    For sure I've done everything I can. I'm a cheap ass I swapped my motor in my Civic. I just figured that the parts manager knew what the hell he was talking about .
  9. Sep 26, 2018 at 4:15 PM
    Bishop84
    Bishop84 Well-Known Member
    D1 will work fine, but its not correct. We used to put D3's on models that used D1's to improve filtering, but never the reverse.
    MurderedTacoV2 likes this.
  10. Sep 26, 2018 at 4:17 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    just like F1's on corollas when your stubborn parts department doesnt want to order more F2's each week :mad:
    But yah bottom line is D1 will work, just make sure you get D3's from now on
    Bishop84[QUOTED] likes this.
  11. Sep 26, 2018 at 4:21 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    The larger has more filter material and volume... as recommended for this engine by the Toyota engineers.
    It should be fine but... if you want to be technically accurate I would change it sooner than you normally would the stock size.
