oil filtration bypass
Discussion in 'Performance and Tuning' started by commtrd, Jul 11, 2009.
  1. Jul 11, 2009 at 2:35 PM
    commtrd
    commtrd [OP] commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    I just finished installing the bypass filter and doing the first oil change. Used 10W-30 Amsoil (6 qts.) since the bypass filter holds 1 qt. Now I will do a complete oil change about every 40,000 miles. Every 3000 miles I will change the bypass filter element (toilet paper roll) and put in a new qt. of oil. So the additives remain good. I used the same bypass filter housing on two Dodge with cummins turbodiesels and two of my previous toyota tacomas. Combined mileage over 300,000 running extended drain with synthetic oil (Amsoil). Many years ago all cars were sold with oil bypass filters. This filtration will get down to under a half a micron as well as catching any entrained moisture, acids, etc. The regular filter cannot come even close to micro-polishing the oil like that.
  2. Jul 11, 2009 at 2:35 PM
    commtrd
    Corpus Christi TX
  3. Jul 11, 2009 at 2:36 PM
    commtrd
    Corpus Christi TX
  4. Jul 11, 2009 at 2:38 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    is this a kit or did you make it yourself?
    i'd be interested in doing something like this sooner or later...
    i've seen these 'toilet paper' roll bypass filters on tons of heavy trucks before
  5. Jul 11, 2009 at 2:40 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    how much did this run you, if you don't mind me asking?
  6. Jul 11, 2009 at 2:55 PM
    commtrd
    Corpus Christi TX
    I think this one was around $120 with the hoses, clamps, filter housing and fittings included. I am not sure if he is still selling them or not. The guy's name is Ralph Woods. Note that this filter setup DOES NOT ELIMINATE THE REGULAR OIL FILTER. It utilizes a pancake valve housing (pictured) to divert a slip stream of oil to the bypass which then returns it to the regular oil circuit. If the bypass was to plug off completely for some reason the engine will still get a full supply of oil. I got the pancake diverter device from Jegs. Would not run extended drain intervals without using some kind of bypass filtration. I also used a needle valve to regulate the flow to the bypass since it will tend to squeal with excessive flow and can hear it inside the cab. That would not hurt anything but it gets to be irritating after a while. I took this housing and diverter off the '07 before trading it in on the '09 so this housing is almost three years old. The way they did the oil filter location on the second gen trucks makes it real easy to do the install.
  7. Jul 11, 2009 at 3:52 PM
    SC4333
    Grant
    San Antonio, TX
    I'm going to look into this. I wonder if there is a pancake diverter that will fit the 2.7L
  8. Jul 11, 2009 at 5:17 PM
    commtrd
    Corpus Christi TX
    Yes there is. I did one on my 2000 model regular cab. It wasn't quite as easy to install as the oil filter hangs down on the passenger side if I remember correctly. Jegs has several different diverter assemblies available; I think the universal is the one I used for both the I4 and the V6.
