Oil flow question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoDinner, Aug 24, 2022.
  1. Aug 24, 2022 at 5:38 AM
    TacoDinner
    TacoDinner [OP] Well-Known Member
    When the oil is flowing through the oil filter, does it pass through the filter element from the inside out or outside in?
    The reason for the question is that I'm considering installing the Baxter filter adapter and wanted to make sure that when I put on the spin on oil filter the oil will flow in the direction the filter was designed for.
  2. Aug 24, 2022 at 8:25 AM
    wj3v
    wj3v Active Member
    2022 TRD Sport
    Outside in. Pleats being on the outside.
    drizzoh and TacoDinner[OP] like this.
  3. Aug 24, 2022 at 10:39 AM
    TacoDinner
    Okay, that's what I was hoping for.
  4. Aug 24, 2022 at 11:03 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    Let me know how it goes with your Baxter adapter, I torqued the adapter to 40 pound feet, and spin on filter only 12 pound feet, and removing the spin on still turns the entire adapter.
    If you're remotely relocating it, nothing to worry about
  5. Aug 24, 2022 at 11:29 AM
    TacoDinner
    I plan to install it directly where the cartridge filter is and only hand tighten the spin on filter. I'll have to wait for the second oil change to see if unscrewing the spin on filter loosens the Baxter adapter.
  6. Aug 24, 2022 at 11:34 AM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Is changing the element that difficult to warrant a Baxter adapter?
    Kev250R and INSAYN like this.
  7. Aug 24, 2022 at 11:38 AM
    TacoDinner
    I don't know. It's my first vehicle with a cartridge filter and I don't want to find out.
    SR-71A and Skydvrr like this.
  8. Aug 24, 2022 at 11:42 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    No, it's not. The extra steps are pulling the old filter out, putting the new one in and replacing the o-ring.
    Kev250R and 44-16 Taco like this.
  9. Aug 24, 2022 at 1:42 PM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    No, it's super easy. I have two Toyotas with the same style and maybe it takes 30 seconds more than a spin off.
    44-16 Taco likes this.
  10. Aug 24, 2022 at 1:54 PM
    Raijin822
    Canada
    2021 TRD OR
    Seems like a lot of extra steps just to create a use for old style spin on oil filters for the sake of "familiarity"
    44-16 Taco, danojeno and 3JOH22A like this.
  11. Aug 24, 2022 at 1:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Do you know if the canister filter's bypass valve opens at the same pressure as the bypass valve built into the OEM filter cap? Could lead to oil starvation and engine damage if the canister filter's valve is set higher.
    Kev250R likes this.
  12. Aug 24, 2022 at 1:57 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is a good video on the removal and reinstall of the filter element and housing.
    https://www.youtube.com/watch?v=4zQZErgkF8k
  13. Aug 24, 2022 at 2:03 PM
    Raijin822
    Canada
    2021 TRD OR
    My question was more of a rhetorical one.
    I personally like the oil filter housing/element setup.
    I run a fumoto valve in place of my drain bolt. When doing an oil change I just flip the valve open and stick the drain nipple into the filter housing and let everything drain while I do a tire rotation.
    0 mess compared to the old spin on filters. Only thing I would recommend is get the aluminum filter housing to replace the plastic one.
  14. Aug 24, 2022 at 2:05 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Because you can does not mean you should.
    I just don't understand this generation of folks that are in such a hurry in life. Honestly what are you going to do with the saved few minutes you might gain with a spin on filter?
    On a side note, it is your truck and your science project. Good luck with that.
    AxisCab likes this.
  15. Aug 24, 2022 at 2:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    Pretty funny, considering spin ons weren't common until the 60's.
    Guess what was before? Yep, cartridge.
    Making cartridge the old style. Or maybe it's called retro now? :D
  16. Aug 24, 2022 at 2:10 PM
    Raijin822
    Canada
    2021 TRD OR
    Pretty neat, did not know that.
    I've always seen spin on filters on older (to me) vehicles and newer ones with cartridges elements.
  17. Aug 24, 2022 at 2:16 PM
    TacoDinner
    I plan to keep this truck for a long time and do the oil changes every 5k miles, so I'm in favor of an easier and less messy procedure. Incidentally, I also plan to install a Fumoto valve. I have installed one on my other car several years ago and it's been great. No worries about overtightening the drain bolt.
    mquibble likes this.
  18. Aug 24, 2022 at 2:39 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    How is it less messy? You literally drain all the oil out of the cartridge in a controlled manner before swapping out the filter element.
    But, ok?
    Kev250R, shakerhood and Raijin822 like this.
  19. Aug 24, 2022 at 2:45 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I like the adapter but will not pay over $50 for one. I would get one so I would need only two different filters for the four Toyota/Lexus vehicles I maintain. Changing the filter is no big deal if you get the filter with the screw-in style drain nipple as oppose to the push-in, which are prone to leaking. If memory serves, the Wix XP, Fram Ultra, and Mobile1 have srew-in nipples. Once you come across one, you can re-use it until the threads start to wear down.
  20. Aug 24, 2022 at 2:56 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You do realize cartridge filters do a better job at filtering than a spin on right?
    Good luck.
    Kev250R likes this.
