Oil for 09 Prerunner
Discussion in '4 Cylinder' started by Paddling4ACure, May 6, 2011.
  1. May 6, 2011 at 7:52 PM
    Paddling4ACure
    Paddling4ACure [OP] New Member
    Shane
    Ocean Beach, San Diego
    09 PreRunner
    Had my Jeep Wrangler stolen and replaced it with an 09 Toyota Tacoma Prerunner 2.7/4 cylinder, manual. Def digging it! I don't have an owner's manual so I'm wondering what grade oil you all are using? I used synthetic in the jeep but am not opposed to using regular. Alohas
  2. May 6, 2011 at 7:54 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Mobile 1 Full Synthetic 5w- 30
  3. May 6, 2011 at 7:56 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    My 2008 2.7 calls for 5w20, but 5w30 should be fine too.
  4. May 7, 2011 at 3:24 PM
    Paddling4ACure
    Shane
    09 PreRunner
    Sounds good... thanks guys.
  5. May 7, 2011 at 3:28 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I use Mobil 1 5-20
  6. May 7, 2011 at 9:49 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    At some point toyota changed what oil is recommended in the 2tr-fe engine. My 05 says 5w-30 but some of the later ones (as stated above) say 5w-20. I think it is printed on the oil filler cap too so you can check there to see what is recommended for your year. I think either will work just fine though.
  7. May 8, 2011 at 5:06 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    my 2008 filler cap recommends 0w-20 and says 5w-20 is ok to use
  8. May 22, 2011 at 2:36 PM
    Ta the Toyota
    Ta the Toyota Member State
    09 PreRunner SR5
    Agree, 0W-20 is the rec. for an '09 too. This is based off the fact of newer technology and the over-all age of your truck. Many who use 30 are older thought or older trucks. Temps too though play a part.
