Oil for 2.7L
Discussion in '4 Cylinder' started by paid4c4, Oct 24, 2012.
  1. Oct 24, 2012 at 8:59 AM
    paid4c4
    paid4c4 [OP] Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    I have 44K on my Taco 2.7L and this will be my first oil change since I bought it. I see in the manual it calls for 05/20 weight. I was thinking about 05/30 Mobil One synthetic. Just wondering if anyone else uses 05/30 instead of 05/20.
    Bill
  2. Oct 24, 2012 at 11:25 AM
    scaplus
    scaplus Well-Known Member
    I run 5-30 in my 06 and I plan on using synthetic after 75K but it all depends on where you live and temperature wise. If you live somewhere really cold, you better off with 5-20 than 10-30.
  3. Oct 24, 2012 at 11:29 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    You don't think that is too light for when you started using the truck offroad.
  4. Oct 24, 2012 at 2:00 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I don't use 10w30 but the best weight of motor oil depends on the climate where you live.
    Following is the average monthly temperature range in Kentucky:
    • MONTH: High / Low
    • JAN: 41 / 25
    • FEB: 46 / 28
    • MARCH: 56 / 36
    • APRIL: 68 / 46
    • MAY: 77 / 55
    • JUNE: 85 / 64
    • JULY: 88 / 68
    • AUG: 87 / 66
    • SEP: 80 / 59
    • OCT: 69 / 47
    • NOV: 56 / 37
    • DEC: 45 / 29
    With these temps, 0w20, 5w20 or 5w30 would be fine. I would not recommend 10w30 because it will not flow as well on cold mornings, although to be honest you won't really notice a difference, but your engine might, over time. I just think 10wt is a little heavy for a 25 degree startup, considering that the OEM recommends something as light as 0w20.
    Summers here in Sacramento can get up to 110 degrees and winters down to 25 degrees -- I've always used 5w30 per OEM recommendation and never had any oil-related problems or any problem of any kind now that I think of it. I've got over 80k miles and it purrs like a kitten.
  5. Oct 24, 2012 at 2:46 PM
    paid4c4
    Northern KY
    I appreciate your response and effort on behalf of my thread. I have edited my thread to read 05/30 instead of 10/30, 05 is what I meant to post. After reading you information I think I'll run 00/30 mobil one which will cover both cold and hot weather. BTW you can keep that 110 degrees!
    Regards;
    Bill
  6. Oct 24, 2012 at 2:54 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    I would stick with what toyota recommends. If you have a problem and they test the oil and it is not 5w20 or 0w20 they can void the warranty. I run 0w20.
  7. Oct 24, 2012 at 3:07 PM
    pat2330b
    pat2330b Member
    Montreal, Canada
    Base 2,7 extra cab
    i use 5-20 and its wonderfull for cold starts in winter time (Est Canada)
  8. Oct 24, 2012 at 4:19 PM
    bsb120
    bsb120 Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    i use 5w-30 mobile 1 synthetic
  9. Oct 24, 2012 at 4:29 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You are really over thinking this, with a big assumption that 20 is too light for hot weather for no good reason.
    I'd go 0w20 over 5w20 before I went the other way to anything/30.
  10. Oct 24, 2012 at 6:36 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I went with 5W30 in mine after noticing the owner's manual suggests that weight for high speed or heavy duty use. FWIW I have seen no adverse effect on gas mileage.
  11. Oct 25, 2012 at 2:33 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Plus the fact the the 0w-20 oils use a fantastic basestock, and the additive package is also of higher quality. It's a win-win. My truck never ran better, sounded better, and it just seemed happier with the Mobil 1 0w-20. Going back to it next oil change for the winter.
  12. Oct 25, 2012 at 4:43 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Been using 5W-30 per the 2006 owner's manual (a.k.a before fuel efficiency mandates came into effect and lightweight oils were recommended to meet fleetwide standards).
  13. Oct 25, 2012 at 8:01 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I use Mobil 1 0w20 synthetic, just go with what the owners manual recommends, they know best in most instances.
  14. Oct 28, 2012 at 9:42 PM
    Scott SD
    Scott SD Member
    My '13 PreRunner has 1200 miles on it and I'll switch over to synthetic this week. I have ran Amsoil for years and love it. It is considered an "exotic" in synthetics, as compared to the others that you can buy at the normal auto parts store. Amsoil 0/20 with the EA oil filter has a 25K change internals. So, I only change the oil once a year on my truck and my wife's car. I average approx. 23K miles per year and my wife around 15K. That is 2 oil changes as compared to 8 with convential oil.
  15. Oct 31, 2012 at 11:03 AM
    DGXR
    Friend
    Sacramento, CA
    My 2006 2.7L has 81k miles and has run 5w30 all its life. Just curious if anyone thinks there might be problems if switched to 5w20. I really don't think there will be a problem but I wanted to ask TW since I am not the most experienced person in the world.
  16. Oct 31, 2012 at 2:05 PM
    91r100gs
    Dan
    Kansas City area
    Will not be a problem, and you might get a between .5 and 1 MPG better. M1 AFE 0w-20 or Pennzoil Yellow Bottle 5w-20 would be what I would recommend for your truck. If you are using any appreciable amount of oil between changes my I would try Maxlife 5w-20.
  17. Oct 31, 2012 at 2:20 PM
    DGXR
    Friend
    Sacramento, CA
    Thanks... my 2.7 engine is in fantastic condition -- starts easily, runs super smooth and purrs like a kitten. The oil level does not move one tiny bit between oil changes every 5k, which is a little strange in itself. I'm glad to see 5w20 conventional oil is available on the market, for a moment I was thinking maybe the lightweight stuff is only available in synthetic.
  18. Oct 31, 2012 at 2:38 PM
    91r100gs
    Dan
    Kansas City area
    Pennzoil YB is a great conventional oil. My oil level never goes down either. Not strange just a tight, well made engine. Millions of satisfied customers.
