Oil for Toyota Tacoma 1998 recently hit 460.000 miles
Discussion in '1st Gen. Tacomas (1995-2004)' started by nicraknes, Dec 13, 2024.
  1. Dec 13, 2024 at 6:35 PM
    nicraknes
    nicraknes [OP] Member
    Peter
    Orlando
    Tacoma 1998
    What's the best oil? Thanks
  2. Dec 13, 2024 at 6:36 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    What's been in it for the past 460,000 miles?
  3. Dec 13, 2024 at 6:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It went 460k on whatever your using so why change it now?
    :deadhorse:
  4. Dec 13, 2024 at 6:38 PM
    MGMDesertTaco
  5. Dec 13, 2024 at 6:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    100% agree.
    What ever oil made it go 460k is good stuff.
    Keep using it.
  6. Dec 13, 2024 at 7:38 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    There have been a lot of contentious "best oil" threads on here over the years. Everybody seems to have their favorite. Seems like the most important thing is changing it regularly. As a guy with a 400,000 mile truck, I go with Castrol GTX conventional 5w30 or 10w30, depending on which one happens to be in stock. Seems like the guys who pay for the synthetic stuff have cleaner valve covers without as much burnt residue/discoloration, but not enough to persuade me to switch.
    At the end of the day, I say put in fresh oil every 5,000 miles and a new filter and keep on trucking. It's easy and fun maintenance that gives you an excuse to inspect the underside of the truck while you're down there.
    Cucvfan and SecureIT2021 like this.
  7. Dec 13, 2024 at 8:17 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    X2 on the whatever you want at a 5k interval. OEM filters are good.
    327k miles and counting.
    I switched to Mobil 1 high mileage a few oil changes ago and the 4Runner leaks a bit less oil than it did before.
  8. Dec 16, 2024 at 9:51 PM
    JuniorVarsity
    JuniorVarsity I'm not a pickup truck guy. I have two.
    PacNW
    1999 Tacoma SR5 4x4, 2021 TRD Sport Access Cab
    This. I'm a noob with only 275k, but I just make sure to change it with synthetic every 5k. The previous owner did it with dino oil every 3k. Doesn't burn or leak a drop.
  9. Dec 17, 2024 at 9:10 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Instead of some fancy oil......I would just use anything readily available....
    however I'd change it more often, way more often........with pretense that the oil passages have narrowed...
    clean fresh oil is best defense for that.
    So often you might even skip the filter for 2 or 3 cycles...
    makes for a 5 min oil change.
    As an engine ages you get less particles shed....
    but your oil gets contaminated more and more with 'blow by' as the rings age....so you have oil/gas mix
  10. Dec 17, 2024 at 10:15 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Costco Kirkland on sale, makes those oil changes like $25 can't beat that.
  11. Dec 17, 2024 at 10:20 AM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Plenty of good oil out there. I tend to use high mileage synthetic for the zinc content.
  12. Dec 17, 2024 at 3:39 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    BWIOS is the best oil….as long as you change oil as kiloyard states
    buy whatever is on sale
