Oil getting dirty sooner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10TRDOFFROAD, Feb 24, 2019.
  1. Feb 24, 2019 at 8:50 PM
    10TRDOFFROAD
    10TRDOFFROAD [OP] Well-Known Member
    Jamf
    Las Vegas
    10 TRDOFFROAD Quad 4x4
    I currently have 145,000 miles on my 2010 TRD. I've change the oil faithfully every 5000 miles since I've owned it. At 100,000 I switched to Full synthetic Mobile 1 high mileage. In the last couple of oil changes I've started to notice the oil is getting dirtier sooner like in 3000 miles whereas before it really didn't look bad until about 5000 miles. So my question is should I be changing the oil sooner or is the 5000 mile interval still acceptable. And has anyone else experienced this.
  2. Feb 24, 2019 at 8:56 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    3k is overkill. 5k is overkill for a full synthetic. send a sample in for analysis (Blackstone labs) at 5k so you can see if there’s any issues.
  3. Feb 24, 2019 at 9:04 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Get a oil analysis done from blackstone lab. It will tell you what you should be doing and if there is a problem.
    inwood customs likes this.
  4. Feb 24, 2019 at 9:12 PM
    Bishop84
    Bishop84 Well-Known Member
    As motors get older, there's more blowby and carbon that circulates, it's only natural that it gets dirtier.
    Oil colour is a poor metric of quality. It's likely just fine and the motor will outlast your lawnmower.
  5. Feb 24, 2019 at 9:36 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    You can’t judge the oil based on color, but it can indicate things. Mobil 1 has a lot of detergents in it and can keep that engine clean for many miles, even when the oil is dark. Oil will typically darken as it is “cleaning” more and some of that is the byproduct of combustion. After a 15 minute or longer drive, pull the dipstick and smell the oil. If there’s a strong smell of fuel then there’s a lot of blow by.
  6. Feb 24, 2019 at 11:43 PM
    10TRDOFFROAD
    Jamf
    Las Vegas
    Good advice! thanks for your input.
  7. Feb 25, 2019 at 4:00 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would also only burn top tier gas.
  8. Feb 25, 2019 at 5:51 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You cannot tell anything substanative about the life of an oil by looking at it.
    If you put brand new oil in your truck and drove a it around town and changed it... it would be black.
    Carbon is black.
  9. Feb 25, 2019 at 7:07 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Did you use regular oil before the switch to Mobil one? If so that would explain it. Synthetics will clean your engine, like already said they have a high amount of detergents. I wouldn't really worry about it.
  10. Feb 25, 2019 at 7:24 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Change your PCV valve if it has not been done.
    Also, about a week or so before you know you are going to change the oil, add half a can of Seafoam to the crank case and let it do its thing.
    Snake oil? Maybe? Maybe not?
  11. Feb 25, 2019 at 9:58 AM
    96carboard
    96carboard Well-Known Member
    The dark skudge in the oil means that the oil is working.
  12. Feb 25, 2019 at 10:04 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    You can't tell shit from looking at the color of oil. Color tells you nothing.
    Blockhead likes this.
  13. Feb 25, 2019 at 11:41 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    I too like wasting my money
  14. Feb 25, 2019 at 12:26 PM
    spitdog
  15. Feb 25, 2019 at 12:57 PM
    rmorse
    Bobby
    Bowie, MD
    Edit - wait, clarify your top tier comment. Because I initially thought you were referring to higher octane but I just realized you might be referring to buying Shell over 7-11 fuel.
    spitdog[QUOTED] likes this.
  16. Feb 25, 2019 at 1:13 PM
    spitdog
    There ya go
  17. Feb 25, 2019 at 2:31 PM
    rmorse
    Bobby
    Bowie, MD
    Ohhhhh. Nvm then. I jumped the gun hahaha
  18. Feb 25, 2019 at 2:36 PM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    My old boss would always when he got a different (used ) truck for our crews, would always check and if the oil looked dirty would add a quart of ATF and drive it another day or so, or about 50 miles and dump it and put new oil in it. Again would drive it till it looked dirty and do the same thing, and eventually it would look good for 3000 miles. His theory was the ATF was high detergent and would clean all the gunk out of the block. He would only use the gm type ATF, not the ford, because it had grit in it, and he wouldn't drive it too hard when he had the ATF in it. He always had good luck with his old trucks.
