Oil gunk under the fill cap revisited - got the Blackstone results back.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BBY2KS2K, Aug 22, 2010.
  1. Aug 22, 2010 at 5:34 PM
    BBY2KS2K
    BBY2KS2K [OP] Jon Stewart / Stephen Colbert 2016
    Lake Stevens, WA
    2005 PreRunner DC
    16x7.5 TRD Bronze "beadlock" wheels without the beadlocks w/ 265 70 16 Bridgestone Revo II tires (non-winter) 16x8 KMC Enduro w/ 265 70 16 Bridgestone Blizzak DMV-1 tires (winter) McGard Spline Drive lugs and locks, Satoshi Grill, BLHM, blacked out badges, Aries side steps, Smittybilt light bar with PIAA 540 plasma ion fogs, Aero-Turbine muffler
    Some of you may remember the pictures I posted of my oil cap earlier this year in this thread...
    http://www.tacomaworld.com/forum/2n...milky-condensation-oil-cap-filler-neck-3.html
    If you missed it, here is what my oil cap and filler tube looked like in February when I did my first oil change.
    I was scared shitless thinking I had somehow had coolant in my oil. Further research found that this is not uncommon despite going against conventional wisdom. I have checked my oil cap and filler neck during every other fill up since then, and as the weather got warmer, the gunk got less and less prevelant to the point where for the last few months there have been ablsolutely no traces of gunk. To be sure there was nothing amiss, I sent a sample to Blackstone to get analyzed. Got the results back a couple days ago. The narrative states there are trace amounts of sodium but they believe it's due to oil from previous changes. That makes sense because the service records indicate that the previous oil changes were done with non-synthetic Mobil 1.
    Here's the Blackstone report...
  2. Aug 22, 2010 at 5:36 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Mine is the same. I freaked out at first too. It's due to not getting the engine to operating temps before shutting off. In the summer time it doesn't take as long to get to temp, hence less residue.
  3. Aug 22, 2010 at 5:43 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    That's nasty. Good to hear the taco will still be fine for 300,000 miles.:D
    OP, that "street racing gone bad" post is quality. Would be nice if kids around here read that.
  4. Aug 22, 2010 at 6:14 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I notice you live in a part of the USA that gets snow and you said as it got warmer the gunk went away. Was the gunk prevalent when you had snow on the ground? You guys salt the roads there right?
  5. Aug 22, 2010 at 6:26 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Dream on my friend, dream on, they use to, not ours.
    take care
    vbibi:(
  6. Aug 22, 2010 at 6:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Hahaha thats funny, I like that really teaches a lesson
  7. Aug 22, 2010 at 8:54 PM
    BBY2KS2K
    Lake Stevens, WA
    2005 PreRunner DC
    We get snow maybe a couple times a year but haven't had it since I've owned my truck. It normally doesn't stick around more than a couple days. The gunk is more prevalent during cold temperatures and with short trips because the engine doesn't get warm enough to evaporate off mositure in the air. So as spring and eventually summer came around, the moisture evaporates off even with the short trips because of the higher ambient temps. We don't salt the roads in my neck of the woods. They use a combination of sand and a chemical de-icer.
    I'm glad you guys like the street racing thread. It's one of the more popular ones on s2ki.
  8. Aug 22, 2010 at 11:49 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    Yeah, that's just water condensate due to the oil not reaching sufficiently high operating temperature to "cook" combustion water out of the system via the crankcase ventilator.
    That's why I installed a remote, bypass oil filter on my engine. The bypass filter actually absorbs the water that forms your orange grunge.
    If you think your filler cap looks bad, visit your local airport and check out the filler caps on the "old tech" engines on light aircraft that only have "road tube"-style crankcase ventilators!
    My machine, a Cessna, drips that goo from the vent tube whenever temperatures are even CLOSE to cool!
  9. Aug 23, 2010 at 3:52 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I have noticed this in my 2006 truck since I bought it new in Mar 2007.
    It has run Mobil 1 since its first oil change.
    My older non-tacomas did it too and my tundras but not to the extent of the tacoma seasonally.
    The Tacoma seems to collect more stuff like your first picture & the color was different which at first concerned me some.
    Last weeks oil change no trace was in the cap or filler neck but the leaves are changing as I type.....
  10. Aug 23, 2010 at 4:03 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    That often happened to a Civic I owned a long time ago. Scared the he'll out of me too when I first saw it!!!!
  11. Aug 23, 2010 at 5:30 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    I had that same issue as well. I had never in all my years living in New England and doing all of my own oil changes seen so much froth in my oil. As far as I can tell this is a Toyota specific anomoly.
    When I did my first winter oil change on the Taco, (running AMSOIL) I freaked out. I thought that I has a major coolant leak into the engine. I had it towed to the dealer for an inspection and pressure/leak check.
    It turned out to be fine. The dealer called their technical reps at Toyota USA and they said that people w/ short winter commutes may experience "slight" buildup of brown-yellow gunk.
    FWIIW, It looked liked an entire can of vaseline made it into my filler neck!
    When the weather warmed up the buildup went away. :dunno:
    I still don't think that nearly that much water should make it into my oil!
    :cheers:
  12. Aug 23, 2010 at 6:00 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I can tell you it is not Toyota specific because I know guys on VW forums were obsessing over the same thing, with pic's very similar to the OP's (of his oil cap) being posted.
    The good thing is, a nice long drive at highway speed made it look normal and their UOA's were normal too.
    I'm interested in just what you're drive regimen is: how long is your commute, and at what speeds? How often do you get out to freeway speeds, for how long? Something like that...
  13. Aug 23, 2010 at 6:56 AM
    viperstd
    Maryland
    At the time is was 3 miles into work, 3 miles home... 0 traffic lights! The only hangup is getting through the fence. I was doing that 4 days/week one week, 5 days a week the other.
    On the weekends I was driving 100 miles up Thursday or Friday night, and 100 miles South Monday mornings.
  14. Aug 23, 2010 at 4:24 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    It's water in the oil, some will condense naturally in the crankcase as the vehicle sits, and water is also a by-product of combustion. As long as the pcv system is working, the water will boil out as the engine reaches operating temperature. Most common cause of this buildup is frequent short trips that do not allow the engine to reach operating temperature long enough to boil off the water, especially in winter. If you live 3 miles from work, for example, the vehicle will need to be driven farther at regular intervals to help avoid this. Or the crankcase ventilation system (pcv) needs some attention...
