oil help?
Discussion in 'Motorcycles' started by RC51, Oct 21, 2011.
  1. Oct 21, 2011 at 8:10 PM
    RC51
    RC51 [OP] Well-Known Member
    mike
    NC.
    08 prerunner DC.
    what oil do you all use? O I have a 09 gsxr 750 what oil ?:confused:
  2. Oct 21, 2011 at 8:11 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    mobil1 5w30 synthetic
    you'll find that to be the most popular
  3. Oct 21, 2011 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  4. Oct 21, 2011 at 8:14 PM
    georgeandkanoa
    jeff
    calgary
    07 tacoma trd
    i should learn to read the whole post
  5. Oct 21, 2011 at 8:14 PM
    RC51
    mike
    NC.
    08 prerunner DC.
    ok I will try that thanks
  6. Oct 25, 2011 at 10:11 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    As a starting point - 10W40 MOTORCYCLE SPECIFIC oil.
    Lot's of guys run Shell Rotella-T with good luck. There's a specific one though, as some of the Rotella oils can cause your clutch to slip.
    I run 20W50 Motul synthetic (7100). I find the shifting gets notchy a little sooner with the semi (5100). In colder temps (spring/fall) I'll switch to 10W40.
