Oil high
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoman2020, Jun 7, 2020.
  1. Jun 7, 2020 at 9:53 AM
    Tacoman2020
    Tacoman2020 [OP] Member
    2016 TRD Sport LB 4x4
    Wondering if anyone else has experienced this. Bought this truck 3 months ago, already had to have a coolant gasket replaced. Now, oil level is high for some reason. I've put ~1,000 miles on it so haven't touched the oil since checking it when i purchased, and I just noticed this today as the oil light came on which prompted me to check it. Looks to be about a quart high for some reason even after it's been running. Wondering if this is something anyone else has run into.
  2. Jun 7, 2020 at 9:56 AM
    Flowie
    Flowie Well-Known Member
    2017 TRD OR
    None yet
    Is it foamy, cloudy, milky? Does it seem like fairly new caramel/ amber oil.
    A quart high sounds like you got antifreeze in it or something.
    Canufixit, tonered, Qwack and 2 others like this.
  3. Jun 7, 2020 at 9:57 AM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    Did you remove dipstick, wipe it off, then insert it, then remove it again to check level?
    kahanabob, Junkhead and wilcam47 like this.
  4. Jun 7, 2020 at 10:11 AM
    Tacoman2020
    The oil is barely dirty, looks pretty fresh. And yes, I wiped off the dipstick and checked a few times because I was surprised as well.
    Junkhead likes this.
  5. Jun 7, 2020 at 10:17 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Was the level correct after the repair? Is the truck sitting level? And who did the last oil fill? Could they have changed the oil along with the coolant (head?) gasket? Did they change the filter? I've seen quick oil change places not change the filter but add enough oil for a new filter.
    Bleep100 and kahanabob like this.
  6. Jun 7, 2020 at 10:18 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Try draining a cup or so from the pan into a clear glass container, mason jars work well. Be sure to get the first off in the jar, let it sit for a bit and see if it separates. Water is more dense than oil and will sit at the bottom of the pan. If all looks good, drain off the excess oil. Keep an eye on the coolant and oil level for a while.
    Or if that's not your thing, take it back to the place that did the repair.
  7. Jun 7, 2020 at 12:19 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Is the engine running while checking? Should be warm and not running
  8. Jun 7, 2020 at 12:23 PM
    Tacoman2020
    So, since that repair I've probably put 400 ish miles on it; not much, but a good bit. I never checked the oil level after purchasing the truck until today. However, the Toyota dealership I brought it to did claim to have checked all fluid levels. I have not gotten an oil change yet, they didn't do it when they replaced that gasket.
    I'll try to drain some oil to see if there is some water in it. Really hope that's not the problem, but I'm not sure what else it could be.
  9. Jun 7, 2020 at 5:30 PM
    Sevenznuf
    Sevenznuf Well-Known Member
    My dealer changed mine first time and I checked it few weeks later after it had sat all night and oil level was about 4 inches above the full mark!!! Took it back and they said it was overfilled (duh) and drained some out!! I’m not sure but suspect they may have not changed the filter but still added the 6 quarts but I can’t be certain!!
  10. Jun 7, 2020 at 5:44 PM
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    Pull your dipstick out, wipe it clean, wait 10 minutes, then reinsert and measure it to get the most accurate reading. The dipsticks on these trucks are notoriously hard to read due to the really thin weight 0w20 oil. If you pull the dipstick, wipe, then reinsert immediately and read it, it can cause some oil to wick up into the dipstick tube and cause an inaccurate reading. Waiting 10 minutes allows the oil to drain fully from the tube to get an accurate reading.
    02Duck, over60 and muskratX22 like this.
  11. Jun 7, 2020 at 5:52 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    or do it in the AM before starting the truck, that's when i always check my oil for the reason you stated.
    02Duck and tonered like this.
  12. Jun 7, 2020 at 5:53 PM
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    This is how I check oil on the Tacoma. Thin dip stick and clean oil is hard for my old eyes to see sometimes!
  13. Jun 7, 2020 at 5:56 PM
    andrewkissam
    Dallas, Texas
    One reason why I like using royal purple. The dark purple oil is easy to read even when brand new and clean.
  14. Jun 7, 2020 at 5:58 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    x2 this is the way to do it.
    over60 likes this.
  15. Jun 7, 2020 at 7:10 PM
    Tacoman2020
    Thanks for the tips! I assumed oil was high which is why the oil light came on in the dash. I'll report back my findings.
  16. Jun 8, 2020 at 9:32 AM
    JEEPNIK
    Always mark the filter if someone else services your vehicle. One of the biggest ripoffs by oil changers is not replacing the filter
  17. Jun 8, 2020 at 9:45 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    What oil light came on? I thought we have one for low pressure and low oil level? But they're not lights but warnings on the center screen. Never see one trip for too much oil?
    Also, why'd you have a head gasket replaced if that's what you mean by coolant gasket? If it was a head gasket that was truly replaced they should have changed the oil at that time.
  18. Jun 11, 2020 at 12:15 PM
    Tacoman2020
    First of all, thank you all for your responses & recommendations. Second of all, I apologize for having wasted your time.
    As it turns out, I may not be suited to own a vehicle from this decade; it's like a space ship to me!
    When the light came on, my immediate thought was that it was a liquid (oil) problem so my first thing to check was the oil (see photo below). Once I checked & double checked, my oil was in fact about a quart too high, leading me to the assumption that I had something leaking into the oil, making it higher, and thus setting off the warning after having not done anything to the oil since purchase 3 + months ago.
    It took a conversation (believe it or not) with my wife, who reminded me that her TPMS sensor was always tripping regardless of tire pressure. We never repaired it and simply do a manual check on the pressure every now and then. That's when I thought to check the pressure in my truck's tires and sure enough, one was sitting at ~20 PSI (way too low) whereas the others were nearly 40 PSI (too high). Turned the truck back on, and there were no longer any warning lights to find.
    Upgrading from a 2005 Camry to the newest generation Tacoma apparently isn't the easiest transition for me! Picture below for dummies like me :)
  19. Jun 11, 2020 at 12:22 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is a TPMS Reset button on the dash way below the steering wheel. Set your pressures and then hold that down until the TPMS light flashes and goes out. This will reset the low threshold.
  20. Jun 11, 2020 at 1:39 PM
    muskratX22
    Dave
    Illinois
    Tacoman There sure are a lot of warnings, bells and whistles on these new vehicles!!
    How did we ever drive without them?? I do like the back-up cam!
