Oil high
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoman2020, Jun 7, 2020.
  1. Jun 11, 2020 at 1:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    Your oil was overfilled when the dealer changed it if its a qt high.
    Examine the low tire carefully. You may have a nail causing a slow leak.
    Now that you've adjusted the air pressures properly (another dealer overfill) be sure to adjust the pressure in your spare. Often forgotten till needed.
    What 'coolant gasket' was repaired?
  2. Jun 11, 2020 at 2:45 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    another light that will be coming on someday is a orange triangle on the speedometer side. when you look in the book one thing it says is low oil pressure. that's BS it is basically triggered my mileage and is nothing but a maintenance required light.
  3. Jun 11, 2020 at 2:58 PM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    careful with this. it sometimes works and sometimes will freeze the system by wiping sensor numbers which then have to be re-entered. like mine. I believe it's because I rotated in a 5th sensor that wasn't stored in the memory, but be careful in any case.
    tonered[QUOTED] likes this.
  4. Jun 11, 2020 at 3:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good tip there!
    I have only the four sensors and have used it many times after airing down / up. I also have TS and the serial numbers stored away, so it would be no big issue for me.
    One note there. We don't need to worry about sensor positions as the system figures it out after hitting the Reset.
  5. Jun 12, 2020 at 5:21 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I reach under and put a magic marker line on my filter before I bring it for service. Then I check that the filter was changed and oil level correct before I leave the service.
  6. Jun 12, 2020 at 5:25 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    An Ah-Ha moment that you can laugh at yourself is quite refreshing. Enjoy your new truck!
  7. Jun 12, 2020 at 3:04 PM
    Tallwalker
    Tallwalker Too tall to hide, too old to run.
    Being Friday, when I saw the title “Oil High” I thought this was going to be something new and akin to eating Tide Pods or something. Guess I have been well trained!
    Glad the OP got it figured out with everyone’s help.
  8. Jun 12, 2020 at 4:25 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Found the millennial
  9. Jun 12, 2020 at 4:41 PM
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    Are dealerships that dishonest anymore?
  10. Jun 13, 2020 at 8:56 AM
    Canufixit
    New England
    I trust mine ... and I think today with all the competition (and internet posts) they realize that customer trust is hard to build an super easy to loose .... However, Mechanics make mistakes, a few disgruntled (especially newbe's doing low paid oil changes 88 hours a day) , are sometimes hurried and I'd rather be safe than sorry .... Besides, Kinda hard to prove to the dealer the mechanic screwed up after the fact of damage/breakdown .... JMO
