Oil in coolant.
Discussion in '1st Gen. Tacomas (1995-2004)' started by jaymeduty, Jan 23, 2012.
  1. Jan 23, 2012 at 11:22 AM
    jaymeduty
    jaymeduty [OP] Member
    Jayme
    bozeman
    95 tacoma 3.4L
    I just changed the upper rad hose because it was leaking where it meets the water pump. When i topped off the rad after changing this hose some oil floated to the top. What cause oil to get into the coolant. It is safe to drive for a couple days until i get it fixed. I drive about 30 miles per day.
  2. Jan 23, 2012 at 11:23 AM
    Sunner
    Sunner Well-Known Member
    Sub'd for input.
  3. Jan 23, 2012 at 11:25 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Bad head gasket will allow oil and coolant passages to leak into eachother.
    Very bad. Check your oil to see if it is milky (sign of coolant)
  4. Jan 23, 2012 at 11:41 AM
    jaymeduty
    Jayme
    bozeman
    Oil is good so i was hoping to avoid head gasket
  5. Jan 23, 2012 at 11:51 AM
    kctmet
    kctmet Well-Known Member
    Orange County, California
    02 DC V6 4x4 TRD
    Check your transmission oil since transmission oil cooler is at the bottom of the radiator.
  6. Jan 23, 2012 at 12:00 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Oil in coolant means coolant in oil...
  7. Jan 23, 2012 at 12:03 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    There is a write up about this happening when the radiator goes bad...
    Was it here, or on the other Taco forum?
    In any even it was called "Taco Shake", and one of the ways to avoid it was installing an aftemarket tranny cooler and replacing the radiator.
  8. Jan 23, 2012 at 12:25 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    You might want to just change your crankcase oil to get a good look. Let a generous sample of the old oil sit overnight in a clear container and see if anything separates.
    As stated, coolant in oil is fatal and when you see the "chocolate mousse" look to your oil, it might be too late.
  9. Jan 23, 2012 at 12:43 PM
    oldstick
    oldstick Medicare Member
    GA
    Has it been skipping, excess water out the tailpipe or overheating or anything else abnormal? Those are common other symptons that happen when a head gasket leaks. I have heard of some funky designs for oil coolers on some vehicles where there is coolant flowing in them as well as the oil (in separate channels). Some are poorly designed with seals that can leak and allow the two to mix.
    Hopefully if it has not run long like this or been overheated, you can fix whatever it is without any further damage.
  10. Jan 23, 2012 at 1:24 PM
    jaymeduty
    Jayme
    bozeman
    Has not been ran long at all. Maybe 100 miles total. It is a 5 speed so i don't think it has a tranny cooler. ( could be wrong it is actually my girl friends truck and i have not been around it long.) No overheating or even getting hot. I have not noticed if there has been excessive water dripping out the tail pipe but i will look into it. when you say it might be too late do you mean it has done catastrophic damage. the truck starts and runs perfect, no smoke, no sweet smell nothing.
  11. Jan 23, 2012 at 1:27 PM
    The Driver
    Raph
    No U R right, that's a malady for Auto's only. Dude, so sorry to hear!
  12. Jan 23, 2012 at 3:49 PM
    jaymeduty
    Jayme
    bozeman
    I did learn that there is an oil cooler that can cause the same problem after talking to a local Toyota mechanic. No just to figure out which one??
  13. Jan 23, 2012 at 5:27 PM
    bowman
    bowman Member
    Dustin
    Etowah N.C.
    2003 whitey ext. cab 4x4
    Bilstein 5100's front and toytec aal with bilstein 5100's in the rear. blue led's in cluster home made carrier drop bracket
    The oil filter screws onto a oil cooler that has 2 coolant hoses goin to it. Since oil pressure is higher than radiator pressure is why you see oil in coolant. I would change the cooler and flush engine coolant with a pressure machine, and change the oil. I did notice the truck was a 95 and Toyota did have a few headgasket problems with the 3.4l v6, but they were for external coolant leaks.
  14. Jan 23, 2012 at 6:12 PM
    jaymeduty
    Jayme
    bozeman
    How much does a new cooler run
  15. Jan 23, 2012 at 9:51 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I'd bet if it's oil in the coolant and no coolant in the oil that it's probably a atf/oil cooler leaking and mixing with the coolant.
  16. Jan 24, 2012 at 8:22 AM
    jaymeduty
    Jayme
    bozeman
    is the oil cooler easy to change. i talked with one guy and said i could bypass it and run it some to see if there is still oil getting into the coolant. what do you think about bypassing it?
  17. Jan 24, 2012 at 11:07 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    ....thought you said it was a manual transmission?
  18. Jan 24, 2012 at 5:24 PM
    jaymeduty
    Jayme
    bozeman
    yes it is a manual. He said that the oil filter screws into a engine oil cooler and they can fail internally causing oil in the coolant. Since the oil pressure is greater than coolant pressure the oil wins mixing with coolant.
  19. Mar 27, 2012 at 3:33 PM
    livinlearn89
    livinlearn89 Member
    Billy
    San Diego
    97 Tacoma
    K&N Intake, Flowmaster exhaust muffler, Donnahoe coils, wide rims
    I'm having same problem. oil in my coolant but not in oil. hoping its not the head gasket. How do I determine if it's the oil cooler??
  20. Mar 27, 2012 at 3:38 PM
    98tacoma27
    Ben
    Not Beech Creek
    You don't have an oil cooler
