Oil in Front of Throttle Body
Discussion in '3rd Gen. Tacomas (2016-2023)' started by M85, Apr 18, 2024.
  1. Apr 19, 2024 at 6:49 PM
    M85
    M85 [OP] Well-Known Member
    Colorado
    2019 SR ACLB
    I checked the PCV valve roughly following the instructions here. https://www.tacomaworld.com/threads/pcv-valve-replacement-help.771466/
    I think it was the video that suggested an adjustable wrench, and that did the trick without having to remove a lot of other stuff. The valve looks perfect, has a healthy rattle, passes air the correct way and blocks air in reverse. I didn't even bother to replace it with a new one. While I had stuff loosened up, I changed the two nearest spark plugs. Five down, one to go.
    I also let some oil out of the filter housing to get it down to the max fill on the dipstick. I don't have a tool to remove the filter housing yet, so I couldn't inspect the filter. I probably could have gotten it off with a rubber strap wrench, but I wasn't confident I could tighten it correctly afterwards.
    I'll check the intake occasionally, but I'm going to assume it's normal unless I find an alarming amount of oil.
  2. Apr 19, 2024 at 8:45 PM
    sublimaze
    sublimaze Well-Known Member
    Definitely a valid argument for installing an oil catch can.
    Blak Shinobi likes this.
  3. Apr 20, 2024 at 6:25 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I put a second catch can coming off the passenger side valve cover vent tube that feeds back into the intake . Not really necessary, but I want to stop any oil vapors going back into the intake .
  4. Apr 20, 2024 at 6:50 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    that’s a really BAD idea unless you have another PCV valve installed in the hose were in the valve cover.
  5. Apr 20, 2024 at 7:14 AM
    BillyE
    BillyE Well-Known Member
    I don’t think it means anything. I’ve seen other vehicles do this. Good idea to replace the PCV valve as others have mentioned.
  6. Apr 20, 2024 at 9:20 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    same kinda, i just know that lot of oil can be cause for an alarm to go off and that some or a lil bit is okay. Its kind of hard to really say with just two pics.Luckily OP is proactive with his maintenance though
    Phlogiston[QUOTED] likes this.
  7. Apr 20, 2024 at 9:21 AM
    Blak Shinobi
    taco
    n/a
  8. Apr 20, 2024 at 1:32 PM
    tiap
    tiap Active Member
    Doesn't matter.
    The more oil in that hose, the more blowby.
    Don't be too alarmed, newer Corvettes and Porsche's have the same issues.
  9. Apr 20, 2024 at 2:01 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    My PCV also seemed ok, clean and lots of rattle.
    I still replaced it, and noticed an immediate improvement in idle, acceleration etc.
    for the cheap coast of a pcv, change it. I did mine at 65K miles.
  10. Apr 20, 2024 at 2:57 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    no, you kind of missed it as well. Having that host is just fine. The problem is is if he doesn’t have a check valve or a PCV valve in that line. An engine backfire could cause a world of freaking shit.
  11. Apr 21, 2024 at 10:47 PM
    tiap
    tiap Active Member
    You responded to vent tube question.
    There have been a gazillion empty vent tubes over decades with no ill effects.
  12. Apr 7, 2025 at 1:22 PM
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    They seems to be a fix for this:
    https://www.tacomaworld.com/threads/rm-engineering-pcv-reroute-kit-info-answers.856205/
