Oil in my Airbox!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nolawall, Jul 19, 2011.
  1. Jul 21, 2011 at 8:55 AM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
    Can't see any reason why Seafoam would cause premature ring wear, but blue oil means that is coming past the rings/valves....and getting burned. Not a good sign!
  2. Jul 21, 2011 at 9:05 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah it could be a case of non seating rings, but usually with a rebuild 99.9% of the time your rings will seat within seconds or minutes of initial start up, hopefully it isn't a case of junkyard bait & switch..
  3. Jul 21, 2011 at 10:10 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  4. Jul 21, 2011 at 2:30 PM
    Nolawall
    Nolawall [OP] "And there I was just minding my own business"
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    6" Fabtech Suspension Lift. K&N Air Filter Cobra 18 CB with 2 3' firestik II antennas
    Well the reason I even used seafoam was because i thought i had it fixed with the PCV valve chnge out. When i pulled the old PCV valve I noticed alot of Gunk just around the PCV valve. So i wanted to make sure i didnt have a buildup of gunk in the motor. The oil is in the intake and i thought maybe that was where the blue smoke for a second was comming from. Like I said beofore the blue smoke only last one second if that. I also changed out the air filter becuse the old one was soaked in oil t the bottom. What I really have not checked was if the oil is overful. I have pulled the dipstick but the truck was hot so I would not get an accurate reading of the level. I am just going to take this engine back and let them deal with it. I am not sweating this to much or as much as I was. I am not going to tell them I have done anything to the motor or the seafoam. I am not even going to tell them I chnged the PCV valve out or the grommet. I changed it out to becuse it was broken. It was all hard and brittel.
  5. Jul 21, 2011 at 3:04 PM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    shitty, good luck
  6. Jul 21, 2011 at 3:15 PM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Yeah thanks
  7. Jul 25, 2011 at 7:54 PM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    OK so I dropped the truck off at the place the engine was rebuilt. First of all I would have sent my weedeater to be worked on here. But since the motor is under warranty i let him take it and see what the issue is. He called me and told me it was the PCV valve was defective. So he changed it and changed the air filter. I have already done this so I dont think it is going to work. But i did here that some of the PCV's are bad when you buy them from Auto Zone or Advanced. So i hope in my case this was just that. But we will see I will take that bitch right back if i get just a little oil in the box. He also told me that was 5-w30 is to thin for my truck. What do yall think?
  8. Jul 26, 2011 at 7:36 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You already know the PCV is not the problem. What does your manual say about the oil?
  9. Jul 26, 2011 at 7:48 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Just because the PCV valve rattled doesnt mean it wasnt bad. If it was running fine except the oil I wouldnt be surpeised if this fixed it.
    Also the local 22re experts garage looks like a crap hole... but that guy is well known in the area for great rebuilds.
  10. Jul 26, 2011 at 1:34 PM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Well i got the truck back today. I ran it to the house checked it at least three times and no oil. So I think it is fixed. So the new pcv i put in there was bad. Now i am paranoid and listen to every little noise my truck makes. When i am at the light and i take off i here something squeek. It not the belt becuase i put the truck in neutral and gas it a few time and even tunred off the AC. Maybe i am just being crazy. but the noise dont start till the wheels start turning. anyone have any idea what this is. it doesnt do it everytime just once every few stop lights.
  11. Jul 28, 2011 at 3:12 AM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Well the oil in the airbox has stopped so now I just got blue smoke at the startup. So now I know its the vlave stem seals. But I looked on youtube for how to do it and it looks easy to change them. Just may take some time.
  12. Jul 28, 2011 at 5:29 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    I dunno but could it be buringn off the excess oil that got into the intake and exhaust? What a few days a see if it settles down any.
    The squeek that you hear is more than likely leaf spring related, nothing to worry about.
  13. Jul 28, 2011 at 6:57 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Why are you wrenching on a motor with a warranty item? That makes little sense to me. Make the guy who rebuilt it fix it!
  14. Jul 28, 2011 at 7:08 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    He did, the guy replaced the PCV...
  15. Jul 28, 2011 at 6:15 PM
    #35
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Well today i found oil in the airbox so it is not the PCV valve. It is something else. This fucking sucks I am going to being it back to the guy that rebuilt it but I dont trust this cat at all. The only reason I am going to him is becuse he is the one who rebuilt it for the owner before me. When i bout this truck I didnt catch this bullshit. So now who is the damn fool. Yeah I am pissed. Could this point dorectly to the valve seals. The motor runs outstanding. I still drive it but I think this is what the issue is.
  16. Aug 3, 2011 at 12:43 PM
    #36
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Ok took the truck back to the guy. Has has had it three days. Has anyone heard of the valve cover ventilation on our 3.4l engines. SO the PCV valve works fine. It has something about air build up in the crankcase and the engine builds up pressure and then the pcv works like a vaccum and sucks in oil though the hose into the intake. Has anyone heard of this?and do our trucks have some type of ventilation on our engines like that. As much research I have done on this how would i miss something like that? And through all of the threads no one has mentioned it to me. Well what do yall think
  17. Mar 10, 2012 at 9:37 AM
    #37
    LCACCON
    LCACCON New Member
    03 tacoma
    Okay I am starting this on this thread as I have done all of this except for press. checks. Have changed PCV twice. HELP. Oh have all the same simptoms. Thanks
  18. Mar 10, 2012 at 9:44 AM
    #38
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Wasn't aware that the V6 had a PCV valve where is it located at?
  19. Mar 10, 2012 at 10:13 AM
    #39
    ourtoy
    ourtoy Member
    Tony
    kingston,washington
    volant cold air intake magnaflow offroad pro
    I had 84 22re that did the same thing. Problem was pluged.and missing vaccum lines.Went through quart of oil everyweek replaced all vaccum lines and problem went away
  20. Mar 10, 2012 at 10:51 AM
    #40
    LCACCON
    LCACCON New Member
    03 tacoma
    It is on the passenger side in front. I have checked alll lines. I have even blown air through them with no glogs found.
