oil in the spakp plugs
Discussion in 'Technical Chat' started by mitiko, Mar 14, 2009.
  1. Mar 14, 2009 at 5:50 PM
    mitiko
    mitiko [OP] Well-Known Member
    lax
    05 prerunner trd
    Hi I change the spark plugs and was all plenty of oil /
    What I sould do.
  2. Mar 14, 2009 at 5:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    *.....beating internet translator against table....*
    Not sure what you are trying to say???
  3. Mar 14, 2009 at 6:20 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    i think he is trying to say he had oil in the holes where the spark plugs go
    maybe i think not sure could be:D jk
  4. Mar 14, 2009 at 6:22 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Check the seals in the valve cover that go around the spark plug tubes.
  5. Mar 14, 2009 at 6:39 PM
    mitiko
    lax
    05 prerunner trd
    Ok my english is not my best but some can undestand/thaks david.
  6. Mar 14, 2009 at 6:54 PM
    David Tarantino
    N.J.
    08 tacoma
    if iam right you have to remove the valve cover and replace the seals
    under each tube where the spark plugs go :D
    its not that bad
  7. Mar 14, 2009 at 7:02 PM
    mitiko
    lax
    05 prerunner trd
    thaks a lot.
  8. Mar 14, 2009 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :anonymous: Sorry...I wasnt sure what you were asking.
    Good call, David. :)
