Oil is Completely empty!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheTacoma, Jan 14, 2017.
  1. Jan 16, 2017 at 6:32 AM
    #61
    TheTacoma
    TheTacoma [OP] Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    135k miles. Coolant looks fine both color and level.
    Well I'm 95% sure the front seal is leaking. Drove it further and it's running down from behind the crank pully.
    If the rear is leaking it's very small, still might drive it further and see if i can confirm a leak or not. Having a trusted family friend/mechanic look at it today.
  2. Jan 16, 2017 at 6:35 AM
    #62
    uwu
    uwu Well-Known Member
    i hate it when this happens!
    TheTacoma[OP] likes this.
  3. Jan 16, 2017 at 7:05 AM
    #63
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    I had to have the front timing cover gaskets replaced on my 2006 at about 125,000. Luckily it was still under the used vehicle warranty from the Toyota Dealer, so it only cost me about $100 for the deductible, rather then over $1000! According to the repair order they did several other seals and gaskets at the same time while in there, so I hope I'm good for a while longer.
  4. Jan 16, 2017 at 8:32 AM
    #64
    TheTacoma
    Birmingham, AL
    Oh goody...I am have no kind of warranty. I should know more by this evening, and I'll be sure to post on here what the outcome is.
  5. Jan 16, 2017 at 9:38 AM
    #65
    Lthompson
    Lthompson Well-Known Member
    try cleaning it best you really can,, and start it and rev it up real good a few times for a few minutes.. May help with the wind scatterin the oil and non being able to pin point the leak. This worked better for me finding mine,
