Oil issue. Accidentally added extra.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by arcticrobot, Oct 22, 2019.
  1. Oct 22, 2019 at 5:15 PM
    arcticrobot
    arcticrobot [OP] Well-Known Member
    2017 TRD Sport manual
    Hi guys. Long story short today wife was driving my taco and she thought that engine sounds weird with some grinding noise. She immediately stopped and checked oil level and it looked like its low. I told her to get 3 qts of oil and add.
    When I got home I let the truck sit, took the dipping stick, sanded it a little bit. Measured again. It appears that I didn't have oil problem, it was just thin oil all over the place after engine running.
    Long story short: I now have about 3/4" higher level than top mark. What do I do? Let it be for another 3000 miles until next service at 40k, or change oil ASAP?
    Thank you.
    Edit: changing it tomorrow or after tomorrow. Thank you guys.
  2. Oct 22, 2019 at 5:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'd definitely drain it out and replace, wouldn't bother with the filter until the next scheduled change. Oil is cheap.
  3. Oct 22, 2019 at 5:16 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    If she truly added 3 qts, do a full oil change. Not going to be a good idea to try and measure 3 qts coming out and then putting drain bolt back in or something like that. Defintely do NOT drive another 3000 with an extra 3 qts in the engine.
  4. Oct 22, 2019 at 5:22 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    As the others have stated drain the oil and add new oil. That's way too much oil in there
  5. Oct 22, 2019 at 5:22 PM
    arcticrobot
    Thank you guys. Will do just that. Will change it tomorrow or aftertomorrow.
    EatSleepTacos likes this.
  6. Oct 22, 2019 at 5:27 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Drain it, install Fumoto valve. With the valve you can easily drain oil without draining it all.
  7. Oct 22, 2019 at 5:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That sound she heard was probably the sound of your main bearings grinding on the crank due to oil starvation.
    I would total the truck.
  8. Oct 22, 2019 at 5:36 PM
    arcticrobot
    How would there be oil starvation if after adding 3 quarts it is now over the top? And wouldn't there be some error light if oil gets too low?
  9. Oct 22, 2019 at 5:53 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    He’s joking around, pay him no mind.
  10. Oct 22, 2019 at 6:09 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    You'll notice he's a trolling 2nd gener
    Junkhead, remgu2000 and Jasonstacoma like this.
  11. Oct 22, 2019 at 6:10 PM
    Tacowin1013
    Drain oil and refill. Want to make sure you get any air bubblels and foam out of there
    arcticrobot[OP] likes this.
  12. Oct 22, 2019 at 7:11 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Another wife story...why 3 quarts? It takes about 1.6 between low and full.
    RTFM.page 456
  13. Oct 22, 2019 at 7:14 PM
    arcticrobot
    honestly was my suggestion. I was 1 minute into important meeting at work, wife called with very concerned voice saying engine makes weird noise and oil is very low. Attaches picture with oil just touching the tip of the stick. I know full oil fill is 6.2 qts. So tell her to get 3 in.
  14. Oct 22, 2019 at 7:15 PM
    Vlady
    Issy, WA
    Took me 30 sec to Google this..
  15. Oct 22, 2019 at 7:17 PM
    arcticrobot
    Message was simple: there is no oil in the system. And no time for troubleshooting.
  16. Oct 22, 2019 at 7:18 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Seems like an easy solution. Drain it all out into a clean pan, measure 6 Qts and put that back in. (there’s still some oil in the filter) That’s what my caveman brain is telling me.
  17. Oct 22, 2019 at 7:25 PM
    Vlady
    Issy, WA
    Im not basting your ballz, but fyi.
    if there is no oil , the big ass red screen will appear under your nose....
  18. Oct 22, 2019 at 8:04 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Logical even if not correct assumption, easy for some to second guess, when they aren't facing the situation.
  19. Oct 22, 2019 at 8:10 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    lol it’s a dipstick, not rocket science.
  20. Oct 23, 2019 at 11:28 AM
    Salty Dog
    Salty Dog Active Member
    Todd
    Ohio and Florida
    White 2019 Tacoma Limited
    I’ve been in a similar sit. The marine industry pumps oil out when it’s time for an oil change. I just pumped 2 quarts back out with an easily accessible oil pump.
