Oil Issues Possible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by texasfootballer, Jun 23, 2020.
  1. Jun 23, 2020 at 5:17 PM
    texasfootballer
    texasfootballer [OP] Member
    09 PreRunner
    Bizarre day, went for an oil change for my 2.7 2009 PreRunner 240,000 miles and the tech claims he only drained 2 quarts out. I have never seen oil on the ground at home or work. Do you think it was straining because my driveshaft was straining for a few months (I got lucky and Toyota replaced the driveshaft for free). I really need some help on this, if I do have small leak is there an additive to stop it, I have been running full synthetic. TIA
  2. Jun 23, 2020 at 5:19 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Did tech accidentally drain transmission fluid?
    crtx likes this.
  3. Jun 23, 2020 at 5:57 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    This
    crtx and whatstcp like this.
  4. Jun 23, 2020 at 6:01 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Two quarts would not give you any oil pressure. Sig45 is right on - the idiot drained your trans pan. Check your oil dipstick and I bet it's way overfilled.
  5. Jun 23, 2020 at 6:01 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Another HALP!!!
    whatstcp likes this.
  6. Jun 23, 2020 at 6:03 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    I thought that was only an issue with the 4.0 V6? Or does the 2.7 have the engine and trans drain plugs close together also?
  7. Jun 23, 2020 at 6:07 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Look into the transmission fluid like these guys are mentioning, but something worth noting is that these 2.7Ls tend to start burning oil after 200k. The lighter rings Toyota seems to be using lose their tension and let oil past the rings and your engine burns it. If everything with the transmission checks out start keeping an eye on your oil level.
    crtx, SR-71A, BassAckwards and 2 others like this.
  8. Jun 23, 2020 at 7:51 PM
    texasfootballer
    09 PreRunner
    It's a standard
  9. Jun 23, 2020 at 8:09 PM
    Sep1911
    2016 Taco
    Then you’re burning oil. Check out the 4 cylinder section. Couple guys are rebuilding their motors @~250k because of it. Keep the oil topped off and it’ll keep going.
    crtx and BassAckwards like this.
  10. Jun 23, 2020 at 8:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This is not uncommon.
    It seems it’s more common with 0w-20 trucks.
    And No, I’m not at all saying you are using the wrong oil.
    I’m not an engineer. I am just stating what I’ve seen reported.
  11. Jun 24, 2020 at 8:16 AM
    Fullboogie
    Dave
    Houston
    2 quarts is not enough to keep the oil pressure and not suck the pan dry. The tech must have been mistaken.
    Sig45 likes this.
  12. Jun 24, 2020 at 4:27 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Check the oil every week and then drive it like you stole it!
  13. Jun 24, 2020 at 4:44 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    This *
    2qts, sumpin' don't add up. o_O
  14. Jun 24, 2020 at 5:33 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Get a new pcv if you haven’t changed it in a while. The old one should rattle.
  15. Jun 24, 2020 at 7:24 PM
    Sep1911
    2016 Taco
    I think you'd be surprised. I've had customers come in complaining their engines ran like shit, with it having like 2 quarts in the pan. The oil was so low that the VVTI system wasn't working properly due to a lack of oil pressure causing the engine to run poorly, yet the oil light didnt come on. IMO typically by the time the oil light comes on theres usually some damage since with these dummy switch oil sensors the aerated oil pressure can be enough to keep them off.
  16. Jun 24, 2020 at 7:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Was this at an Iffy-Lube type joint?
  17. Jun 24, 2020 at 8:07 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I agree the oil pressure light is useless, it doesn't come on until oil pressure drops to 1-2psi, by then it's too late.
    Sep1911[QUOTED] likes this.
