Oil Leak 01 tacoma 3.4L v6
Discussion in '1st Gen. Tacomas (1995-2004)' started by Seimo, Mar 2, 2013.
  1. Mar 8, 2013 at 4:27 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    Have you unbolted the inspection cover off the bell housing? Take that off and see if the oil is coming from behind that cover. If it's dry in there, then look elsewhere like the valve cover or something else leaking oil that is traveling back there. You can see it in the pictures you posted. It has 3 bolts and it come off so you can access the torque converter bolts on the flexplate.
  2. Mar 8, 2013 at 9:41 PM
    trded
    trded Active Member
    CA
    02 PreRunner TRD 2WD
    TRD Catback TRD Headers TRD SuperCharger TRD 7th Injector & ECU
    I used to be a tech a toyota. A quick and easy check without dye would be to apply a paper towel to the area. If its brown its engine oil. If its red its automatic trans and hopefully you're not bleeding. :p
  3. Mar 9, 2013 at 7:36 AM
    Yotacoma92
    Yotacoma92 TacoLover
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    Westin brush guard, smitty built nerf bars, roll bar, K&N air filter, Helo 17" Rims with 285-65-17 BFG KM2's, OME 2in lift springs, 0-2.5 lift Bilstein 5100 struts, OME 3in lift leaf springs, 5125 bilstein rear shocks, Projector HID headlights, Blacked corner lamps.
    Looks like a rear main leak bud. i have the same problem and im going through about a quart a week. its a 12 hour flat rate job to replace the rear main and you are going to pay a good amount of money to have it fixed at a shop. Jus for a little added info, if your living in sacramento, the shop rates are prolley going to be around $75-$100 an hour and at 12 hours.... yea lots of money. best bet is to use the dye. you can buy it from a parts store or NAPA. once you find out where it is leaking, either rear main or rear of the oil pan (if ur lucky 6.4 hour job gotta drop the front diff) find a buddy with a hoist, or a high lift jack and tall jack stands and jus work on it. i will try and get the procedures off of all data or mitchell for you.
  4. Mar 14, 2014 at 9:57 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I'm in Sacramento too. Been looking for a good shop but no luck. If you find one can post the name and how much they charge for that seal?
  5. Apr 10, 2014 at 9:27 AM
    Trapperr
    Reno, NV
    You ever get that leak fixed OP?
  6. Apr 10, 2014 at 1:50 PM
    Sick 2002 Taco
    Sick 2002 Taco New Member
    Patrick
    Kansas
    2002 SR5 ext cab bare bones
    bedliner hood protector, coil over rear springs, bedliner lower 1/4 on the side, bull bar and PIA lights
    I had this happen on my 02 3.4 v6 a few years back, I tracked it down to the rear main. I had the dealer put a new one in due to the pulling transmission etc. It was costly, like 600 bucks but it leaked again about 6 months later and the dealer replaced it again for free. Based on the dates you've probably already had it fixed.
  7. Apr 15, 2014 at 5:40 PM
    Seimo
    Seimo [OP] Member
    It stopped leaking for now. I looked around and found a pretty good and trustworthy shop. It's called neighborhood garage by sunrise and coloma road. Pretty good reviews also on yelp. Hope it helps. I have a cousin that will do it for me at a 350 price so that's who I am going to when I'm ready.
  8. Apr 15, 2014 at 5:41 PM
    Trapperr
    Reno, NV
    Thanks for the heads up on that shop! That's only a few miles from my house.
  9. Apr 15, 2014 at 5:42 PM
    Seimo
    Seimo [OP] Member
    I think neighborhood garage quoted me close to 600 to do the job.
  10. Apr 15, 2014 at 5:44 PM
    Trapperr
    Reno, NV
    I'll have to look in to how much of a pain it is to do myself. I'm pretty tight on $$$ right now but oddly, mine stopped leaking too. Pretty odd
  11. Apr 15, 2014 at 5:58 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Just a thought, but try changing your oil with high mileage oil, and throw a little extra seal sweller in it as well. Might cure it. The problem usually is the seal drys out, seal swellers soften them back up and might help
  12. Apr 19, 2014 at 12:06 AM
    Seimo
    Seimo [OP] Member
    If you want to do it I can ask my cousin but he prob wants 400 to do it.
