Oil leak, AT oil temp light
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bluecord, Oct 25, 2021.
  1. Oct 25, 2021 at 7:27 AM
    Bluecord
    Bluecord [OP] Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    Drove the truck back from Albert Pike in Arkansas yesterday morning. Drove around 75 miles per hour for about an hour on the interstate. When I pulled up at the bottom of the off ramp, my AT oil temp light came on. I was still around 12 miles from home, so I drove on. After a couple of minutes the light went off. It came on once more at a stop light, and then did not come on again. When I got home I looked under the truck and saw what I believe is oil on the front of the transmission pan. I just changed the oil and filter about 2000 miles ago. I'm hoping this is the valve cover gasket which I know needs changing, but have been putting off. My fear is it's something worse (rear main seal, head gasket, etc). The truck has about 289,000 miles and runs great. How can I confirm where this oil is coming from since I can't see all the way up the back side of the engine? I'll take some pics when I am able if that helps.
  2. Oct 25, 2021 at 7:54 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Heat soaked engines do all manor of strange things .
    Clean things best you can keep an eye on fluid levels
  3. Oct 25, 2021 at 11:18 AM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Clean and monitor fluid like mentioned. Carry 2 extra quarts with you just Incase. How about that crush washer? New or reuse the old? Check the torque on the valve cover and tighten if necessary. My valve cover began to leak. 2 bolts toward the firewall were lose. Is the fluid brown or red? That definitely helps narrow it down
  4. Oct 25, 2021 at 12:41 PM
    Bluecord
    Jeff
    Louisiana
    New crush washer when oil changed which was only about 3 weeks ago. Drove it to Albuquerque and back with no noticeable issues. I tightened the valve cover bolts (that I could reach) about 9 months ago. The fluid is brown and I'm pretty sure it's oil. Guess it could be old transmission fluid though. Does it have a different smell to it than motor oil? I didn't have much time to investigate when I got home yesterday, and I'm back at work today. Going to have to let it sit until I can do some deeper digging. Luckily I have another vehicle.
  5. Oct 26, 2021 at 6:48 AM
    Bluecord
    Jeff
    Louisiana
    Checked the oil fill cap last nite and looks normal (no pink milkshake). Oil level is at the top of it's range just like after I changed it. Transmission fluid level is in range for the engine being cold. Radiator fluid looks normal. I guess a little oil can look like a lot of oil when it spreads around. Ordering all the stuff to do valve cover gaskets today. Also doing spark plugs, wires, and tube seals, throttle body and IAC cleaning and gaskets, plenum gaskets, half moon and cam plugs, and PCV valve and grommet. Am I missing anything I should be doing while the vale covers are off? While I'm in there, I'm going to replace the timing belt and water pump. Might as well put in the upgraded alternator and wiring set I just got from @TheMachinist also. I've watched the @Timmah! videos on the valve covers and he makes it look pretty easy. Hoping to get it all knocked out in a 3 day weekend. And hoping it solves my oil leak problem.
