Oil leak between manual transmission and transfer case ...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dentedporsche, Sep 3, 2020.
  1. Sep 3, 2020 at 4:57 PM
    dentedporsche
    dentedporsche [OP] Well-Known Member
    Ron
    2018 TRD off-road DCSB
    I was in process of doing the accumulator hack on my manual transmission line and noticed some oil residue where the rear of the transmission and front transfer case castings meet.
    My dealer is almost 2 weeks out so will take it in but wondering if anyone has had same issue and what was diagnosis.
    The leak appears to be minor but the truck only has 23K miles. I replaced all fluids except transfer case over 2 years ago when the truck had 5K miles and never noticed a leak until recently.
    Update:
    Just got back from dealer ... t-case oil seal was leaking from the output shaft. Replaced seal, gasket, and fluid under warranty.
    Never had much faith in dealers so hopefully it will take care of problem. I already noticed that it was refilled with 75W-90 vs 75W straight.
  2. Sep 3, 2020 at 5:16 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
  3. Sep 3, 2020 at 5:35 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    There's an o-ring seal between the trans and t-case, has to be that.
    shakerhood likes this.
  4. Sep 3, 2020 at 5:40 PM
    Bishop84
    Bishop84 Well-Known Member
    It could just be sweat, just take photos of it, and if it starts to drip then its a concern.
    It's very common to see residue there.
    kahanabob likes this.
  5. Sep 3, 2020 at 5:42 PM
    2020cement
    2020cement Active Member
    From what I’ve read on here, unless it’s dripping they won’t fix it under warranty. They will say it’s “sweating” and it’s normal.
