Oil leak from back up light switch. Is it possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mrim0706, Jul 21, 2025 at 8:39 AM.
  1. Jul 21, 2025 at 8:39 AM
    Mrim0706
    Mrim0706 [OP] Member
    Hello all,
    I knew there was very minor leak on timing chain cover... but I started to see some dripping on my drive way, and caught this on the picture.
    I couldnt find a leak above light switch, so I am guessing it's from the light switch.
    Is it possible to have oil leak from back up light switch? (I have this replaced about 10 months ago. It's strange that it didn't leak for past 10 months and suddenly it starts dripping.)
    Should I give it a shot on replacing it with new back up light switch?
    Any recommendations for new installation to prevent any oil leak?
    Like can I use it with light coat of gasket sealer?
  2. Jul 21, 2025 at 8:41 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It might be leaking through the connector
    I'd just replace it
  3. Jul 21, 2025 at 8:44 AM
    Mrim0706
    Would you recommend putting the gasket sealer around the new connector?
  4. Jul 21, 2025 at 9:02 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    No the crush washer should do the job
    Nothing should be leaking through the body of the connector. Any sealant in there would just make a goopy mess.
    Torspd likes this.
  5. Jul 21, 2025 at 9:14 AM
    Mrim0706
    Gotcha. Thank you so much! I will give a shot!
  6. Jul 21, 2025 at 9:22 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Take the connector off and see if there is fluid in the inside the connector, if so then the switch is internally leaking.
  7. Jul 21, 2025 at 10:17 PM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    Possibly the switch leaking internally my powerstroke diesel did this to me check the connector.
  8. Jul 21, 2025 at 10:18 PM
    Mrim0706
    Thank you all. I will have it replaced tomorrow and see how it does.
  9. Jul 21, 2025 at 10:23 PM
    Owenhall
    Owen
    Lift 33s
    Oil will also somehow manage to soak in to the wires and can travel through the harness would definitely clean the connector if there is oil in it.
  10. Jul 22, 2025 at 10:26 AM
    Mrim0706
    Thanks for the advice. I inspected the leak and thankfully its just at the switch. No trace on upwards or sideways to harness yet. Glad I caught this on time. I will give a shot on replacing it and see if it still leaks in few days.
  11. Jul 23, 2025 at 10:45 PM
    Mrim0706
    Thanks for the help guys. I replaced my back up light switch to Toyota part and It hasn't been leaking for 24 hours. My old switch had relatively smaller washer and it wasn't from Toyota. I am guessing since the weather was getting hotter here in San Diego, so it was easier to leak. I will give another week, but if you guys dont hear back, you can assume there is no leak.
    Thanks again!
  12. Jul 23, 2025 at 11:00 PM
    Owenhall
    Owen
    Lift 33s
    Ok hopefully it doesn’t leak on you.
