Oil leak front differential
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02ttaco, Apr 11, 2011.
  1. Apr 11, 2011 at 12:15 PM
    02ttaco
    02ttaco [OP] Member
    Tyler
    Maryland
    02 tacoma trd
    three inch spacer lift with blocks in the rear
    i noticed my truck was leaking a little oil this morning and this is what i discovered. The picture is on the front differential where the axel goes into it. Is this a bad cv joint or a bigger problem? I can also hear a squeal coming from up front while driving. Also, the cv joint on the drver side (leak side) seems to have alot of play (front to back). Thanks in advance for any help
  2. Apr 11, 2011 at 12:37 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Looks like the axle seal has gone bad.
    That undercarriage is screaming for a pressure washing. I would hate working on that.
  3. Apr 11, 2011 at 12:39 PM
    Manwithoutaplan
    ID
    I had this problem on my 2 gen where the drive side cv joint was really loose. For me it was just a CV seal in the differental which was like 100 bucks to fix. I had a pretty good size oil leak for mine to.
  4. Apr 11, 2011 at 1:24 PM
    mike sacc
    mike sacc Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    i had abad seal on the same side in my 01.couldnt keep oil in it. ichanged it on saturday, the seal was $13 from the dealer. disconnected the tie rod end ,lower balljoint and bungeed everything off towards the back off the truck.
  5. Apr 11, 2011 at 1:30 PM
    mike sacc
    r.i.
    mine was nasty too.i took the skid plate off to keep an eye on it which just let it blow all over everything. the truck got a new frame inthe fall .you couldve eaten off of it.not anymore
  6. Apr 11, 2011 at 2:00 PM
    02ttaco
    02ttaco [OP] Member
    Tyler
    Maryland
    02 tacoma trd
    Macgyver-
    Of course it figures i went wheeling the nigght before i noticed the leak
    Mike-
    The CV boots still look like they are in decent shape but i have a 3in spacer lift and was curious if this could have been caused by the angle of the axel now that i lifted it...Also, is it safe to drive it like this for a while without further damage to the axel/differential?Thanks again for advice guys.
  7. Apr 11, 2011 at 2:24 PM
    macgyver
    Brad
    Canton, GA
    Could be due to the spacer...but it would be hard to determine that.
    Just keep the fluid topped off and you should be able to drive it..provided it doesn't get worse.
  8. Apr 11, 2011 at 5:01 PM
    mike sacc
    r.i.
    it leaked less than aweek and i couldnt keep oil in it. its also apain in the balls getting oil in it. good luck.
  9. Apr 11, 2011 at 9:24 PM
    02ttaco
    02ttaco [OP] Member
    Tyler
    Maryland
    02 tacoma trd
    I topped the fluid off and the diff. has been dry since doing so. I will keep an eye on it..hopefully it wont leak. Is is uncommon for dirt/mud to get in around the axle seal resulting in a 'temporary' leak?
  10. Apr 12, 2011 at 4:36 PM
    mike sacc
    r.i.
    i would think if the seal got disturbed it wouldnt be seated right but anythings possible. good luck.
