Oil leak??? Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpaceMonkey, Aug 7, 2009.
  1. Aug 7, 2009 at 11:36 AM
    SpaceMonkey
    SpaceMonkey [OP] Well-Known Member
    Houston, Tx
    06 PreRunner
    I was changing my oil the other day and noticed oil under the engine, oil pan, and crossmember. Where is this coming from? Do I have a bad seal somewhere? Will the dealer warranty the work. My 3yr/36k warranty ran out. Thanks.
  2. Aug 7, 2009 at 11:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    More than likely, It came from when the filter was removed.....
