Oil Leak near drivers front axle
Discussion in 'Technical Chat' started by Manlaan, Jul 19, 2010.
  1. Jul 19, 2010 at 2:44 AM
    Manlaan
    Manlaan [OP] Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Well, I'm a bit confused here about this oil leak that started happening recently.
    The oil is about the consistency and color of motor oil or gear oil, but it looks like its coming from the drivers inner cv boot on the largest lip. I felt around the boot where it seemed like the oil is coming from and didn't see or feel any cracks or tears. There's a good splatter of oil right around the mounts/brackets like oil was being slung from the cv boot. It really seems way too thin to be grease though.
    Any ideas?
    I sprayed it down with cleaner tonight, but will take pics of it the best I can tomorrow if it helps.
  2. Jul 19, 2010 at 6:31 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Well check your front diff oil level, also it could be grease oil separating. When grease gets very old it can no longer hold mixture of oil in solution so oil easily separates. next step it will start drying up.
  3. Jul 19, 2010 at 9:07 AM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    I wanted to check the front diff level but the last person to put on the filler plug decided to goober up the end. If its on nearly as tight as the rear one was, there's no way I'll be able to get it off with out completely stripping it. So, I'm just going to make the dealer that put it on take it back off and put in a new plug. Silly me for thinking I can be lazy and let someone else change the gear oil would actually be less of a hassle....
    I guess I'll open the boot and take a look at the grease and see what it looks like. Probably about due anyway.
  4. Jul 19, 2010 at 9:33 AM
    BlueT
    NorthEast
    Did you ever repacked your CVs? or they are original?
  5. Jul 19, 2010 at 2:44 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    Pretty sure they're original, so its kinda getting to be that time anyway after 140k.
