Oil Leak on 2016 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stevend1, Nov 7, 2019.
  1. Nov 7, 2019 at 2:28 PM
    Stevend1
    Stevend1 [OP] Member
    Huntsville Alabama
    Tacoma TRD Off Road 4X4
    I am trying to find out if anyone else has had problems with an Oil Leak on their 2016 Tacoma, TRD Offroad, 4 X 4. I first had a leak about 8 to 10 months ago. After 2 visits to the Toyota Dealer, it was determined that I had a leaky Valve Cover Gasket on the Drivers side. Gasket was replaced under warranty. Now, amount 10 months later and about 8 - 10 thousand miles, smell has returned as before. No visible leaks from outside view. Please let me know if you have had the same issue/problem.
  2. Nov 7, 2019 at 2:34 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Welcome to tacomaworld!
  3. Nov 7, 2019 at 2:41 PM
    duckytw
    duckytw Well-Known Member
    Check under powersteering pump... that area had leaving timing chain gasket on some early builds.
    MannyS and Man of Steel TRD like this.
  4. Nov 7, 2019 at 4:23 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Are you still under warranty?
    shakerhood likes this.
  5. Nov 7, 2019 at 4:29 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    If you don't see oil leaks are you sure that's the problem? When you say smell is it through the AC vents etc?
  6. Nov 7, 2019 at 4:30 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    If it's the timing chain cover, then yes its a common problem. Requires removing the engine or disassembling the entire front end to replace.
  7. Nov 7, 2019 at 4:38 PM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    Took mine in today. Crawl underneath, shine a flashlight up towards the power steering pump. If you see oil drops or residue, it is the timing chain cover. Also make sure you have a warranty. It's a minimum of $4000 to repair. If you'd like for me to post what I received today, I'll be glad to.
    Man of Steel TRD likes this.
  8. Nov 7, 2019 at 4:43 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  9. Nov 7, 2019 at 4:43 PM
    ANTupLIFE
    Anthony
    Chester, VA
    For the sake of it. They will drop the transmission, remove the engine, and replace a lot of gaskets and o-rings. Thank goodness for an extended warranty.
  10. Nov 7, 2019 at 4:44 PM
    ANTupLIFE
    Anthony
    Chester, VA
    Also worth mentioning, that not only is it a common occurrence. I'm certain many have this going on and have no clue. (For now.)
    It was a thing on the 2nd gens as well.
    shakerhood and Man of Steel TRD like this.
  11. Nov 7, 2019 at 4:44 PM
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    This. I had to have my front crank seal replaced at 25,000 miles. It was leaking out of the timing cover. I thought it was power steering fluid.
    shakerhood and ANTupLIFE like this.
  12. Nov 7, 2019 at 4:48 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    The service tech said they have had thos crank seals completely blow out of some of the trucks they have seen. Keep an eye on it all.
  13. Nov 7, 2019 at 4:53 PM
    ANTupLIFE
    Anthony
    Chester, VA
    I'm not sure when mine started, but one day I decided to check my oil and it was a 1/4 of a quart low. Probably not long after 70k which was back in July. It's awfully defined now, so the Taco is parked until it's scheduled in for the repair. No need to risk a blowout. Lol
  14. Jan 13, 2020 at 6:20 PM
    Stevend1
    Huntsville Alabama
    Well I went to a Tire Discount Store for normal oil change. Luckily for me, one of the mechanics is a Tacoma Geek like me. We discovered that oil was leaking around the same area as when initial leak happen at 35000 mile. Have taken to Toyota dealer about 3 times and they were unable to find. Will take in next week with pics of where the leak is. Just glad I found out where it is coming from so hopefully can get it fixed and get rid of the sporadic smell. Will update post as I go along.
  15. Jan 13, 2020 at 6:56 PM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    mine is in right now for the timing cover leak. apparently they replace nearly all the seals and gasgets on the engine, so the service advisor says. they didn’t pull the block on mine, they just took the entire front end off. thank god for warranty’s.
    mine is an early 2016 sr5 4x4 btw.
  16. Jan 14, 2020 at 3:53 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    so glad they gave me a lifetime warranty on the drivetrain...
  17. Jan 23, 2020 at 8:31 AM
    Stevend1
    Huntsville Alabama
    Well the mechanic at Tire Discounter took pics of leak and sent to the Toyota Service department for me. Service Department has ordered new Valve Cover Gasket. Waiting for gasket to arrive. Am very happy that the Toyota Service Department finally confirmed leak. Am anxious to see if 2nd Valve Cover Gasket fixes the leak. I have searched the internet and have not found that this is a common problem. I just want to get it fixed while my warranties cover it.
  18. Jan 23, 2020 at 10:20 AM
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Went in for oil change and they said I might have a timing cover leak. It’s still under warranty as I just hit 50,000 but I’m worried about everything that needs to be taken apart and reassembled. Hoping they don’t screw up anything else while they fix it.
  19. Jan 23, 2020 at 10:22 AM
    ANTupLIFE
    Anthony
    Chester, VA
    You'll be fine.
  20. Jan 23, 2020 at 10:34 AM
    ryan760
    ryan760 Well-Known Member
    You'll know pretty quickly if they screwed something up, either by way of strange noises or check engine light. And there's always a warranty on engine repairs, so I wouldn't worry about it.
