Oil leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LQQKatmy06, Oct 14, 2007.
  1. Oct 14, 2007 at 1:47 PM
    LQQKatmy06
    LQQKatmy06 [OP] Carolina Alliance
    T-VILLE, NC
    06 SR5 V6 DC LB TRD Sport 4x4 AUTO. 3" TOYTEC 885 coils w/AALs, ALL-PRO UCAs, 285/70/17 NITTOs, KMC HOSS in BLACK
    Dealer will not repair leak, Toyotas rule; Its not a leak until a drop of oil hits the ground. The truck has 20,000 miles on it.
  2. Oct 14, 2007 at 2:11 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    drive it til it blows up under warranty and make em replace it. i'd just have it documented that u complained of an oil leak and they did nothing about it.
  3. Oct 14, 2007 at 3:14 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    Yes keep your records even after warrenty it should be covered because it was noted while still in warrenty. Audi does the same thing they have 3 stages of leaks and until it is driping we did nothing about it but clean it off and let it ride. Car companys go figure
  4. Oct 14, 2007 at 4:07 PM
    LQQKatmy06
    T-VILLE, NC
    Thats funny, the mechanic must have used some spray degreaser to clean the area cause it was all over the water pump and side of the block. When they brought me back to the bay my truck was on the hoist and he said he found my leak and pointed at the hose I had on my oil filter catch. I told him it was on top and had to drop the truck to see it. The pic I posted was after leaving the dealer, being cleaned and driving about 45 miles. So by the end of the week it should be alot worse and back I'll go.
  5. Oct 14, 2007 at 4:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if it was mine.......id be bitching till they did a rebuild or put in a new motor one. 20k miles and a leak like that.........should never happen, so they should fix, no questions asked!!
  6. Oct 14, 2007 at 4:55 PM
    LQQKatmy06
    T-VILLE, NC
    I noticed it about 2 months ago and thought it was just dirt from normal driving, looked a little closer and it was oil.
  7. Oct 14, 2007 at 7:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    like i said bro.....bitch until they fix it, or take it to another dealership and see if they will fix it. its definitely under warranty...........dont let anyone bs ya!! and if ya have to, call toyota corporate!!
