Oil Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mississippi Taco, Mar 5, 2016.
  1. Mar 5, 2016 at 6:00 PM
    Mississippi Taco
    Mississippi Taco [OP] Member
    Madison, MS
    01 TRD 4x4
    Leer
    5VZFE
    Over the past couple months I've noticed a pool of oil where I park my truck in the driveway. I can see fresh oil around the valve covers, but it's hard to imagine that that much oil is leaking from there. Bottom side of the engine has oil everywhere. The truck has 280,000 and i'm afraid the repairs may be more than the engine is worth at this point. Thoughts?
  2. Mar 5, 2016 at 7:04 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    That's a typical leaking point. Just to be certain its the valve cover gaskets, clean all the oil off and come back to it in a day or so. See where it's leaking from
  3. Mar 5, 2016 at 9:12 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    With that many miles every gasket in the thing probably needs to be replaced. How often do you add oil? Better be keeping a close eye on it if it's leaking that bad.
    My old '78 Ford Bronco had a leak problem like that. Trying to find exactly where it was all coming from, the real question was where it DIDN'T leak. Had to add a quart of oil to it every 3 days. I finally caved in and bought a complete gasket set, pulled the motor and installed new gaskets top to bottom. Will do the same to the Taco when the time comes, one of my valve covers has some seepage going on currently but nothing to worry about yet.
