Oil leaking from somewhere- 2000 2.7 Prerunner
Discussion in '4 Cylinder' started by 2000TRDTaco, Mar 9, 2014.
  1. Mar 9, 2014 at 6:17 PM
    2000TRDTaco
    2000TRDTaco [OP] Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    So my 2000 prerunner has 178,xxx miles on it and has been the best truck ever....never left me stranded, just basic maintenance to date and no major problems
    Noticed recently some oil on the skidplate and under the truck on the passenger side (it seems to coat the underside at speed, which is why I think its down low on the engine because it gets blown towards the back of the truck)......have not seen any spots or leaks on the ground under it yet......check the dipstick each time I fill up with gas and it never seems to lose any (always on the full mark)
    Im guessing its either the oil pan gasket seal or the valve cover......it doesn't seem to get worse, its just always there
    Any help would be appreciated
    Thanks
    UglyBetty likes this.
  2. Mar 9, 2014 at 6:57 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Valve cover gaskets are easy and cheap. Oil pan gaskets not so much. Before buying any parts try torqueing the valve cover bolts. Sometimes they loosen a little over the years and allow the gasket to leak. Just don't over tighten them, I would recommend using a 1/4" drive ratchet if you have one.
  3. Mar 9, 2014 at 8:09 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I have the same leak on my 2002. I think it is coming from the oil pan gasket but I'm not 100% sure. Even though it's leaking I've never noticed that I've lost any oil between oil changes. It's not urgent but I would also like to know where mine is coming from.
  4. Mar 9, 2014 at 8:24 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    It could be from the flux capacitor.
    No, seriously, without pictures we can't tell you a definitive answer.
  5. Mar 10, 2014 at 4:26 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    I had the same thing on my 2001 2.7 prerunner, I did the oil pan gasket with RTV, it still leaks, just not as much!
  6. Mar 10, 2014 at 5:30 PM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    Well at least I know I'm not the only one with this problem
  7. Mar 11, 2014 at 9:39 AM
    FALlover
    FALlover Well-Known Member
    luziana
    98 tacoma SR5, camo paint
    trail gear bumbers, warn 9000
    a place to check: the oil filter perch, right where it meets the block...mine was leaking there and it got oil everywhere. its a really easy seal to replace if that is it. don't forget to check there.
    for the longest time i thought my oil pan gasket was leaking but no
  8. Mar 17, 2014 at 6:56 PM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    After hearing everyone's advice on what my leak could be, I got under the hood and truck on saturday and starting looking really hard to try and find this problem
    I found that about half of the valve cover bolts were about 1 1/2 turns loose (tightened those) and also found a couple of the oil pan bolts were also a tad loose, so after getting all that fixed, I took the skidplates to the car wash and washed them and the underside off very well, so hopefully I can see if that helped
  9. Mar 17, 2014 at 7:09 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Timing chain cover? That's what my 97 was and sounds similar
  10. Apr 1, 2014 at 8:26 AM
    2000TRDTaco
    Corey
    Angier, NC
    00 Prerunner
    Well it looks like it is the timing chain cover......crawled under it while running and could see oil seeping out.....how difficult is this to fix? Im very mechanical minded .....does the head need to be pulled to take the cover off?
