oil level after oil change
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockyTacoma, Aug 8, 2010.
  1. Aug 8, 2010 at 8:52 AM
    RockyTacoma
    RockyTacoma [OP] Well-Known Member
    Dojo
    colorado
    2002 tacoma trd
    stock
    so i changed oil on my 02 TRD 3.4l. yesterday..i let oil drain for almost an hour, while i was doing something else. replaced oil filter and fresh oil of 6 quarts.... this morning i check dip stick still not at full level? owners manual says with filter its 5.7 quarts. i put in 6 quarts and still not at full level??? i dont get this?
  2. Aug 8, 2010 at 8:58 AM
    747 function > form
    1st Gen.
    Is it showing on the dipstick? I don't have an answer for your question, but so long as you're above the lower limit notch on the dipstick, I think you'll be good to to.
    FWIW, I put in 5 qts. on my 5VZ-FE oil changes, and it always shows in the middle on the dipstick (i.e., in between the lower limit notch and the upper limit notch).
  3. Aug 8, 2010 at 8:58 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    check for leaks at the filter and drain plug. Also are you sure your reading the dipstick correctly IE after the engine has been sitting for about 10 minutes without running.
  4. Aug 8, 2010 at 9:01 AM
    RockyTacoma
    Dojo
    colorado
    2002 tacoma trd
    stock
    oil level is in the middle of lower and upper notch...after 6 quarts
  5. Aug 8, 2010 at 9:03 AM
    RockyTacoma
    Dojo
    colorado
    2002 tacoma trd
    stock
    ....i drove my truck yesterday, and parked it over nite, and check oil level on leveled surface
  6. Aug 8, 2010 at 9:05 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    so its between the marks on the dipstick? If so your fine. Thats how mine reads after 5.5 quarts.
  7. Aug 8, 2010 at 9:34 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    6 quarts is probably exactly at the middle of the dipstick right? nearly every manufacturer says that anywhere between the top and bottom of the lines on the dipstick are in the "acceptable range" so they usually aim for the middle. cars come off the assembly line with the oil in the middle.
  8. Dec 28, 2010 at 2:18 PM
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    I have the opposite issue. Brand new Tacoma, 2010, purchased Nov. 30. Obviously does not need oil. But dipstick shows oil 2 inches above 'full' mark. Wipe stick and dip again. Same reading. Truck runs fine, no issues. I assume the dipstick simply picks up oil from somewhere while it slides up. Dunno. Same results if I wait overnight.
  9. Dec 28, 2010 at 2:32 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Here's my info:
    Change oil/filter - using 5.7qts
    Start truck, let run for 30 sec.
    Let truck sit for 10 min.
    Check.
    My truck uses 5.7 qts, dead nuts.
  10. Dec 28, 2010 at 3:01 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    you used 6 quarts but some of it went into the oil filter.....
  11. Dec 28, 2010 at 3:02 PM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    ok thats where it should be
  12. Dec 29, 2010 at 2:02 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    5.7 qts with filter?? Wish someone had told me that last night FFS. (see my thread)
