Oil Level Automatic Tranny 09'
Discussion in 'Technical Chat' started by Mon Leb, May 6, 2009.
  1. May 6, 2009 at 6:10 PM
    Mon Leb
    Mon Leb [OP] Well-Known Member
    St-Jean-sur-Richelieu, Quebec, Canada
    2009 4X4 SR5-TRD Sport
    Hi there!
    You guys know how to check the oil level of an automatic transmission 2009? :confused:
    There's no dip stick!:rant:
    ML
  2. May 6, 2009 at 6:14 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Its sealed, only needs maintenance every 100k miles.
    There is an overflow underneath the truck. When you open it some should seep out.
  3. May 6, 2009 at 7:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont touch any of the plugs under the tranny. Too many people have dumped thier fluid...
  4. May 7, 2009 at 11:30 AM
    Mon Leb
    All right guys, I won't touch a thing!
    Thanks!:D
    ML
  5. Aug 13, 2009 at 1:25 PM
    glandnut
    glandnut Reserve Squirrel Hair
    Florida
    16' 4Runner TEP, 01' Ext cab 4x4
    secret stuff.
    I just got my 09', and the guy who went over the truck controls and operations told me they were not only sealed, but filled with synthetic.
  6. Aug 13, 2009 at 3:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is true.
  7. Aug 13, 2009 at 3:10 PM
    TacoSter
    TacoSter Well-Known Member
    Chicago Burbs
    Had 08 taco, in a 4runner now
    question - on my 08 V6. The morons at jiffy lube today were doing something and I overheard them talking about the tranny / oil.
    I asked if they messed with it and they said they could not cuase the plug was sealed.
    Any chance they coulda F'd something up?
  8. Aug 13, 2009 at 3:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The plug is not sealed. There have been a few instances in which the tranny was drained instead of the engine when an oil change was attempted. Never use Jiffy Lube.
  9. Aug 13, 2009 at 4:07 PM
    TacoSter
    Chicago Burbs
    Thanks for the info.
    I went down and looked at the tranny plug they must have opened it or wiped it down with an oily rag. (oil is around it). Is there any way to check the tranny fluid level ??
  10. Aug 13, 2009 at 4:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The tranny has to be at a certain temp to check the oil level. Best bet is to take it to the dealership. Personally, I would complain to the manager of the place you took it to, and make them pay for an inspection from the dealer.
  11. Aug 13, 2009 at 4:37 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I hear people say that the '09 auto tranny is "sealed" with no dipstick. But my '09 auto as a dipstick. Maybe there's a difference in the 2.7 and the 4.0.
  12. Aug 13, 2009 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is a difference between the 2. You have a 4 speed auto, and the 4.0 Has the new (er) 5 speed unit.
