Oil Level Issue
Discussion in 'Technical Chat' started by SURFTACO, Mar 1, 2010.
  1. Mar 1, 2010 at 11:54 AM
    SURFTACO
    SURFTACO [OP] Well-Known Member
    New Jersey
    09 Tacoma
    3'' Pro Lift, 275 70 17 Tires Rear Suspension TSB Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover
    I was looking around the engine bay today and noticed oil around the oil filter (a noticeable amount). I went ahead and checked the oil level with the dipstick and it indicated above the second divot. What are your guys thoughts on this? How much of a problem is this? How much is too much oil? Thanks in advance :confused:
  2. Mar 1, 2010 at 9:34 PM
    ofrd4fun
    ofrd4fun Well-Known Member
    Vancouver BC
    05 DC 4x4
    FJ Cruiser wheels, air bags, 5100's @1.75, TC UCA's, bi-xenon HID's
    What's between the filter and the motor??? Something to do with the tow package and engine oil cooler??? (my tacoma does not have the tow package) I would repair it. Probably an o-ring or something minor. It does not sound like you're down on oil though.
  3. Mar 2, 2010 at 6:12 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Looks like nobody wiped out the the catch basin after an oil change. When the filter is pulled off, the oil drains into that silver looking thing. On the bottom is a hole that a cup, piece of tubing etc can be used to catch the oil. there is a black cap on it by default from the dealer. Perhaps that last person to change your oil never removed that cap and just left the oil in there. A rag and a degreaser will clean that up nice. Do that, and see if more oil forms. If it does, then obivously it is a problem.
  4. Mar 2, 2010 at 6:16 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    You're saying that your oil level is ABOVE the high mark on your dip stick, and oil appears to be seeping out around the filter? I don't know much, but I've seen/heard that too much oil is as big a problem as not enough. How much oil did you put in at your last change?
    I can't offer a solution other than to do an oil change and put in only as much oil as it needs.
  5. Mar 2, 2010 at 6:27 AM
    SURFTACO
    New Jersey
    09 Tacoma
    Thanks for the insight fellas. I'm not sure how much oil was put in. I went to a good year store to get my oil changed. I am due for another oil changed. Just out of curiosity any know the max amount of quarts it can hold?
  6. Mar 2, 2010 at 7:02 AM
    mws4ua
    Birmingham
    5.5qts
    I change my own... It's a great amount b/c I can buy a box of 6 qts, throw out 5 bottles, and have half a bottle to put behind the back seats just in case.
  7. Mar 2, 2010 at 7:24 AM
    SURFTACO
    New Jersey
    09 Tacoma
    5.5 qt huh? alright thanks a lot ! I actually just talked to my mechanic; I'm going to be bringing to him later this afternoon check it out. Ill let ya guys know the outcome.
    You know, I should start doing my own oil changes: Once the cold snap is gone !
  8. Mar 2, 2010 at 11:01 AM
    SURFTACO
    New Jersey
    09 Tacoma
    The catch basin was never drained from the previous oil change. All is well. thanks again
  9. Mar 5, 2010 at 11:32 AM
    Bulldogs1
    Bulldogs1 Member
    Tim
    MD.
    06' Dbl. Cab 4x4 SR5
    Chrome Putco Grille, K&N drop in filter, 15% tint, Black Altezza style taillights, Eagle Eye projectors & Kenwood DDX512 DVD receiver, nitto terra grapplers, Paint matched N-Fab side steps & lift next.
    Yea....start changing your own, you'll probably even enjoy....i'm no mechanic but worked at a garage changing oil....much more fun when you can get the vehicle in the air tho.
  10. Mar 5, 2010 at 11:56 AM
    SURFTACO
    New Jersey
    09 Tacoma
    I was thinking of starting to do my own. Thanks a lot.
