Oil level question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TriniPhantom, Jul 6, 2019.
  1. Jul 6, 2019 at 9:46 AM
    TriniPhantom
    TriniPhantom [OP] Well-Known Member
    Bay Area, California
    2018 Tacoma TRD Off Road DCSB
    Prinsu roof rack, Budbuilt Sliders, Avid Bumper Guard, MESO Ultimate Turn Signals, Door sill decals, Raptor Lights, Tailgate inserts, Mudflaps, Tri-fold Tonneau, DC Motorsports Muffler Tip, TVD Vinyl Decals, Many Interior Mods.
    When my engine is cold, the oil level is like 1/2 inch above the high mark. When it's hot, it on the mark. Is this normal/ok?
  2. Jul 6, 2019 at 10:13 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    When it’s cold/hasn’t ran for a while will be your true oil reading as that’s when all the oil has drained to the pan. 1/2” seems like a lot. Did the dealer or yourself do the oil changes? I would say you’re probably over and should drain some but hopefully someone else can chime in with more expertise. I’ve always measured when it’s cold and made sure it’s at the proper level. Too much oil will damage your seals and components.
    Junkhead likes this.
  3. Jul 6, 2019 at 10:27 AM
    TriniPhantom
    Dealer did the oil change. Went to them this morning and talked to the head tech. He checked it and said it's okay. He said when it's cold, it will always be higher than warm. As long as it's on the mark when warm, that is fine. Still questioning this though.....
  4. Jul 6, 2019 at 10:35 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    What does the manual say?
    BillsSR5 likes this.
  5. Jul 6, 2019 at 10:39 AM
    Rustytaco71
    2018 4Runner
    Well thankfully Toyota provided us with a manual.
    nick_b, Hobbs, CusterFan and 2 others like this.
  6. Jul 6, 2019 at 10:54 AM
    TriniPhantom
    Yea just checked it. So according to manual engine must be at operating temp. So therefore, measuring when cold will always lead to higher reading?
    Stocklocker likes this.
  7. Jul 6, 2019 at 10:57 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Like others said, when its cold all the oil drains to the pan. If its showing half inch above the high mark thats like half a quart of oil you dont need. I would say its definately overfilled.
    You should not see your oil level above the second dot. Too much oil is definately not good. Just my 2 cents.
    Good luck! :cheers:
  8. Jul 6, 2019 at 11:01 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Oil when cold has to be at the high mark. Been changing oils for 40 years.
    Robnik likes this.
  9. Jul 6, 2019 at 11:01 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Drive it to operating temperature, let sit for few minutes, check. Shouldn't be more than a few mm above the full dimple.
  10. Jul 6, 2019 at 11:20 AM
    Rustytaco71
    2018 4Runner
    After your next trip when you get home, let it sit for 5 minutes and go check your oil level. Report back with your findings.
  11. Jul 6, 2019 at 11:24 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    You got a manual with yours? How did you get a manual??
    Vbpiper likes this.
  12. Jul 6, 2019 at 11:28 AM
    FloridaSon
    FloridaSon Well-Known Member
    White SR Gen 3
    Some oil at the top of the engine when running may drain into the pan when off and cold, which might raise the oil level a bit. Not sure how much tho.
  13. Jul 6, 2019 at 11:33 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Hobbs[QUOTED] and CusterFan like this.
  14. Jul 6, 2019 at 11:38 AM
    Robnik
    Rob
    Greenacres, Florida
    Just keep it around the full mark within a 1/4", hot or cold. Don't over think it, you'll be fine.
    CusterFan likes this.
  15. Jul 6, 2019 at 11:42 AM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    The dipstick in the 3.5 is very hard to read with a cold engine. With clean oil it’s even harder. Check it hot after sitting for 5 minutes as the owners manual states.
    If it’s good hot, don’t worry about it.
  16. Jul 6, 2019 at 11:58 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    With 6.2 Qts mine is in the middle when cold.
  17. Jul 6, 2019 at 12:18 PM
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    I got 2 manuals, one in the glove box, the other attached to the engine. You have to live in Canada though to get it on a TRD OR AC.
    Good thing Toyota put that note about having that rag under the dipstick when you pull it out of the engine or I might have failed at checking my oil level.:rolleyes:
    Vbpiper and Hobbs[QUOTED] like this.
  18. Jul 6, 2019 at 12:21 PM
    Hobbs
    Yep…
    Checking the oil is not for the layman.
  19. Jul 6, 2019 at 1:07 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    If my dipstick has oil on it I'm good to go!
    suaveflooder likes this.
  20. Jul 6, 2019 at 1:58 PM
    Clipper16
    Clipper16 Well-Known Member
    Gil
    Tennessee
    2018 TRD Sport ACLB Intense White Tech and Pro
    Same story, same response from the head tech.
