Oil level question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TriniPhantom, Jul 6, 2019.
  1. Jul 6, 2019 at 5:01 PM
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    It’s fine. Operating temperature measurement is what counts.as the engine cools the oil passageways and accessories such as oil squirters, valve lash adjusters and all the oil galleys in the block and heads bleed down to the pan. But the dipstick is intended to be read at operating temp after a recent shut down.
    TriniPhantom[OP] likes this.
  2. Jul 8, 2019 at 3:20 PM
    Chukar Chaser
    Chukar Chaser Well-Known Member
    Pete
    So Cal
    2019 TRD OR 4X4 DCLB
    That's for damn sure. I just did my first oil change and that fresh oil is very hard to see on the dipstick.
    TriniPhantom[OP] and TD90S like this.
  3. Jul 8, 2019 at 5:26 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Take some fine sand paper and rub the tip a touch ( inserted pun) it'll grab the oil and make it much easier to see.
  4. Jul 8, 2019 at 7:46 PM
    K_Sandhu
    K_Sandhu Well-Known Member
    Karan
    Castro Valley, CA
    2017 Double cab TRD off-road 4x4 long bed
    When oil heats up it expands and when it is cold it is thicker. That's why Toyota says to check the oil when engine is at operating temperature. Allowing the engine to sit for 5 mins allows all of the oil to come back to the proper measuring level.
    What I usually do is right after turning off the engine, I pull the dipstick out and let it sit outside for 5 mins and then reinsert after cleaning off course. Lightly scrubbing the dipstick with fine sandpaper does help as well.
  5. Jul 11, 2019 at 6:10 PM
    ingot
    ingot Well-Known Member
    re: not being able to see clean oil on the dipstick, while I haven't tried this with the tacoma, when I had the same issue on a previous car I bought one of these white plastic drain snakes since they're basically the same shape as the dipstick shaft:
    https://www.homedepot.com/p/BrassCraft-20-in-Plastic-Hair-Snake-BC00112/305468409
    Take a pair of cutters and snip off the barbs before using. Then hold the actual dipstick against it and mark on the white plastic so you know how far to insert it, and also mark the "full" level. It's a little bit easier to see the oil against the white plastic compared to the regular dipstick.
    I thought about drilling a series of very small holes (maybe 1/32" or 1/64" diameter, every 1/8" or so (in the plastic), above and below the "full" mark since the holes that reached oil would stay filled with oil, for a few seconds anyway, and the ones not reaching oil would be empty. I didn't end up doing that on the previous car, but the Tacoma oil is so close to colorless when it's in a thin layer that it might be worth it to try.
    This particular one in the link (20") might not be long enough for the Tacoma, but I'm sure there must be longer ones.
  6. Jul 11, 2019 at 10:28 PM
    bluzharp
    bluzharp Well-Known Member
    Central AR
    19 OR DC LB Cement (the slowest color)
    Pro Suspension, Roadmaster overloads, Diamondback
    I bead blasted the tip of the dipstick. No problem reading it now.
  7. Jul 12, 2019 at 6:58 AM
    ingot
    "Back in the day," dipsticks used to always have either stamped cross-hatching or knurled patterns in the tip section. But in this day and age of shaving every penny of production costs off, anything that clears the hurdle of : "will anyone sue us, or not buy the vehicle, if we remove this" with an answer of 'no' gets removed.
    On the plus side, the fact that the oil barely breaks a sweat in lubricating this engine is a GOOD thing. I've had new vehicles that already had some discoloration of the oil by the second tank of gas.
