Oil on back of transfer case?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Johnsmyname, Apr 7, 2025.
  1. Apr 30, 2025 at 3:33 PM
    #41
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Yes, but if you have a lazy tech, he can pick & chose what he wants to do, clean it off again, say he saw nothing & hopes you go away...
    Not saying thats the case here, not like pulling a transfer case is difficult...
    But then again, I dont know if they specialize or if theyre bumper to bumper.....
    Just giving you some pointers to cover yourself, just incase it goes sideways again...
  2. Apr 30, 2025 at 3:36 PM
    #42
    Johnsmyname
    Johnsmyname [OP] Active Member
    Thanks Slater, any and all advice is welcome.
  3. Apr 30, 2025 at 3:42 PM
    #43
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Toyota corporate won't cover the bill at full freight. The dealership gets a fraction of the labor costs, not the full hourly rate. So they'd rather get your car off the rack and get another vehicle in the air that isn't a warranty issue
    That's why we see these rush jobs with the warranty frame replacements. They're not getting 40 hours at full retail labor price, they're getting "warranty rate" which is much less.. those techs are under pressure to go as fast as possible
    Johnsmyname[OP] likes this.
  4. Apr 30, 2025 at 3:47 PM
    #44
    Johnsmyname
    That makes sense.
  5. Apr 30, 2025 at 5:16 PM
    #45
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    As other members have said TC input seal.
  6. May 1, 2025 at 5:31 AM
    #46
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    But OP said this 90 day warranty is through Carmax. So they are footing the bill, not Toyota? Toyota is just doing the work. Thats how I read it
  7. May 1, 2025 at 6:04 AM
    #47
    Johnsmyname
    The car has two warranties. One through dealer CarMax and one through Toyota because it’s only 3 years old with 25k mikes. CarMax is taking responsibility for whatever Toyota charges or doesn’t repair. Toyota is still obligated to fix anything power train related.
    Jakerou likes this.
  8. May 1, 2025 at 6:11 AM
    #48
    SR-71A
    Zack
    Southern Maine
    Oh shit thats right. I forgot this was a new-ish truck
  9. May 1, 2025 at 6:11 AM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea you are correct, he did say it was a carmax warranty..
    I've dealt with 3rd party warranty companies and they are notoriously cheap and frugal.
    Maybe the dealership has to "know for sure" where the leak is coming from or the warranty company will reject the claim? It's still pretty silly though. Like, you're looking up at 2 gear boxes.. it's either coming from this one or that one, they butt together and there's an empty space where they meet and bolt up. Just pull it apart and fix it. It's not like there's a million seals in there, literally just 2.. and they're cheap.. do them both..
  10. May 1, 2025 at 6:40 AM
    #50
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    A leak is a leak is a leak: They don't get better, even with a good clean-up. ;) To me, it looks like its coming from the drain-plug area: maybe they re-used the crush washer and then over-tightened it because they always leak when you re-use them. Or if someone did a fluid change on it, they probably over-tightened the fill-plug too. The air-stream under there is now blowing the oil everywhere. If it's not obvious where it's coming from, clean it again and visually check it every ten miles or so.
    Welcome to TacomaWorld! :proposetoast:
  11. May 1, 2025 at 9:35 AM
    #51
    Johnsmyname
    They got a drip this AM and said it was only the TC side. They are replacing the seal. I will make sure the area is very clean and check it weekly to make sure it's not coming from anywhere else.
    3JOH22A likes this.
