Oil on just 1 spark plug?
Discussion in 'Technical Chat' started by dwd1985, Jul 27, 2019.
  1. Jul 27, 2019 at 3:44 PM
    dwd1985
    dwd1985 [OP] Active Member
    US
    Was giving my 2nd Gen V6 a tune up, and 1 of the 6 spark plugs had oil on it. Pic below. I'm not super technically savvy, any idea why only 1 (the plug closest to the driver, drivers side "rear" plug) has oil and the others dont?
  2. Jul 28, 2019 at 9:42 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The plug is not in my hands, so I can't say for sure, but it looks like the oil is likely coming from outside and not the result of rings/valves/guides/seals leaking internally.
    You may have a leaking valve cover gasket. I would eyeball that area more closely.
    What yr. is your truck? The head gasket alarmists will chime in if you say 2005 or 2006.
  3. Jul 28, 2019 at 9:46 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    This was my initial thought as well. The business side of the plug appears relatively clean. I suspect your oil problem is above the plug, most likely a valve cover.
  4. Jul 28, 2019 at 9:48 AM
    dwd1985
    US
    It’s a 2006...and you’re correct, the threads are clean. The oil was on the top part of the plug.
