oil on spark plug thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yamabiker, Mar 13, 2012.
  1. Mar 13, 2012 at 7:07 AM
    yamabiker
    yamabiker [OP] Well-Known Member
    Utah
    2006 Double Cab SR5 TRD
    Changed out my plugs last night. I installed the last set 30k miles ago. All of the old ones looked pretty good. Dry etc. The plug on the driver's side, closest to the firewall (away from the oil fill spout) had a dry spark end which looked normal, no additional carbon etc. Yet, it had oil on the threads. No oil has leaked, dripped, been poured, etc. into the hole. I inspected the hole for the spark plug and there was no dirt or oil. So the oil must have come from the the cylinder? But the end of the plug was dry and not any different from the others. Anyone have any explanations. Something to worry about or no big deal? Engine sounds fine and runs fine. Mileage had been going down a bit. I was hoping new plugs would bring it back up.
    Thanks
    Yamabiker
  2. Mar 13, 2012 at 8:34 AM
    hawlisjawt
    hawlisjawt Well-Known Member
    Is it oil or maybe anti-seize ?
  3. Mar 13, 2012 at 8:36 AM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  4. Mar 13, 2012 at 9:58 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    It seems to be normal on the drivers side closest to the plug....your not the first one to notice that when people change there plugs...its happened to me first hand with my 05' and my 11' I installed my supercharger at 11,000 miles on my 11' and had same thing...oil on the plug so it seems to be a characteristic of the 4.0L
  5. Mar 13, 2012 at 7:14 PM
    yamabiker
    Utah
