Oil on Sparks plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by atrain20210, Dec 3, 2016.
  1. Dec 3, 2016 at 4:42 PM
    atrain20210
    atrain20210 [OP] Active Member
    Aaron
    Vermont
    07 Tacoma TRD Off-Road
    Oil catch can, DIY aux input, 7 Pin trailer plug relocate
    I changed my spark plugs today and noticed the drivers side closest to the radiator spark plug had some oil above the threads. Did some looking and it could possibly be caused by a valve gasket leaking. Anyone have any experience with this? Any write ups on this? Are there any other possibilities that would cause this?
    By the way it's a 4.0l with about 170k on it.
  2. Dec 3, 2016 at 8:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is above the threads it would also be above the seating surface wouldn't it? If it is like the image below yes it is a seal leaking around the spark plug well and you will have to pull the valve cover to replace it.
    Here is a How To: http://www.toyota120.com/forum/showthread.php?t=26163
    Torspd likes this.
  3. Dec 4, 2016 at 6:54 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    ^Yep now there is a real leak but a couple of drops around a spark plug isn't.
  4. Dec 4, 2016 at 9:59 AM
    atrain20210
    Aaron
    Vermont
    Yeah it wasn't that bad just a few drops. thank you this put my mind at ease
